some abbreiviations for some newbies
This is a sticky topic.
    http://www.fordfuelinjection.com/?p=15
    so when you see something abbreviated and have no fucking clue
    ABS- Anti-Lock Brakes
    A/C - Air Conditioning
    ACCS - A/C Cycling Switch
    ACC - A/C Clutch Compressor
    ACD - Air Conditioning Demand
    A/C on - Air Conditioning ON circuit
    ACP - Air Conditioning Pressure
    ACT - Air Charge Temperature sensor
    ACV- Thermactor Air Control Valve
    A/C WOT - Air Conditioning WOT off relay
    ADC - Analog to Digital Converter
    ADJ - Adjust
    A/D - Analog to Digital
    A/F - Air to Fuel Ratio
    AFR - Air to Fuel Ratio
    AIR - Secondary Air Injection / Thermactor
    AIRB - Secondary Air injection Bypass
    AIRD - Secondary Air injection Diverter
    ALDL - Assembly Line Diagnostic Link
    ALT - Alternator
    AM1 - Thermactor Air Bypass solenoid valve (TAB)
    AM2 - Thermactor Air Diverter solenoid valve (TAD)
    AOD - Automatic Overdrive transmission
    AODE - Automatic Overdrive Electronic transmission
    AODE-W - Automatic Overdrive Electronic Wide-ratio transmission
    ARC - Automatic Ride Control
    A/T - Automatic Transmission/Transaxle
    ATDC - After Top Dead Center
    AXOD - Automatic Transaxle Overdrive
    AVOM - Analog Volt-Ohm Meter
    B+ - Battery Positive Voltage
    BATT+ - Battery Positive Voltage
    BARO - Barometric Pressure
    BDC - Bottom Dead Center
    BLR - Blower
    BOO - Brake On/Off switch
    BP - Barometric Pressure sensor
    BPA - Bypass Air
    BTDC - Before Top Dead Center
    CAC - Charge Air Cooler (intercooler)
    CANP - Canister Purge solenoid
    CBD - Closed Bowl Distributor
    CCC - Converter Clutch Control
    CCD - Computer Controlled Dwell
    CCO - Converter Clutch Override
    CCRM - Constant Control Relay Module
    CCS - Coast Clutch Solenoid
    CEL - Check Engine Light
    CFI - Central Fuel Injection
    CID - Cylinder Identification sensor
    CKP - Crankshaft Position
    CKT - Circuit
    CM - Continues Memory
    CMP - Camshaft Position
    CO - Carbon Monoxide
    CO2 - Carbon Dioxide
    CPP - Clutch Pedal Position
    CPS - Crankshaft Position Sensor
    CSE GND - Case Ground
    CTS - Coolant Temp Sensor
    DAC - Digital to Analog Converter
    DI - Distributor Ignition
    DIS - Distributorless Ignition System
    DLC - Data Link Connector
    DOHC - Dual Overhead Cam
    DOL - Data Output Line
    DPFE - Delta Pressure Feedback EGR
    DPDIS - Dual Plug Distributorless Ignition System
    DPI - Dual Plug Inhibitor
    DRW - Dual Rear Wheel Axle
    DTC - Diagnostic Trouble Code
    DTM - Diagnostic Test Mode
    DVOM - Digital Volt/Ohm Meter
    E4OD - Electronic 4-Speed Overdrive
    EAIR - Electronic Secondary Air Injection
    EAP - Electronic Air Pump
    ECA - Electronic Control Assembly
    EEC - Electronic Engine Control
    EEC-IV - Ford’s fourth generation EEC system
    E-fan - Electric Cooling Fan
    ECM - Electronic Control Module
    ECT - Engine Coolant Temperature sensor
    ECU - Electronic Control Unit
    EDF - Electric Drive Fan relay assembly
    EDIS - Electronic Distributorless Ignition System
    EED - Electronic Engine Control
    EFI - Electronic Fuel Injection
    EGO - Exhaust Gas Oxygen sensor
    EGR - Exhaust Gas Recirculation system
    EGRC - EGR Vacuum Control solenoid
    EGRV - EGR Vent solenoid or system
    EGT - Exhaust Gas Temperature
    EI - Electronic Ignition
    EPC - Electronic Pressure Control
    EPT - EGR Pressure Transducer
    ER - Engine Running
    EVP - EGR Valve Position sensor
    EVR - EGR Vacuum Regulator
    EVTM - Electrical & Vacuum Trouble Shooting Manual
    FC - Fan Control
    FF - Flexible Fuel
    FFS - Flexible Fuel Sensor
    FFV - Flexible Fuel Vehicle
    FI - Fuel Injector or Fuel Injection
    FMEM - Failure Mode Effects Management
    FMU - Fuel Management Unit
    FP - Fuel Pump
    FPDM - Fuel Pump Driver Module
    FPM - Fuel Pump Monitor
    FPR - Fuel Pressure Regulator
    FRPS - Fuel Rail Pressure Sensor
    FTO - Filtered Tach Output
    FTP - Fuel Tank Pressure Sensor
    Fuel pump primary circuit - relay control side (85-86)
    Fuel pump secondary circuit - relay power side (30-87)
    GCM - Governor Control Module
    GEN - Generator / Alternator
    GND - Ground
    GRND - Ground
    GVW - Gross Vehicle Weight
    HC - Hydrocarbon
    HEDF - High Speed Electro Drive Fan
    HEGO - Heated EGO sensor
    HEGO G - HEGO Ground circuit
    HFC - High Fan Control
    HFP - High Fuel Pump
    HLOS - Hardware Limited Operating Strategy
    HSIA - High Speed Inlet Air
    HO - High Output
    HO2S - Heated Oxygen sensor
    HO2S 11 - Right Front O2 sensor
    HO2S 21 - Left Front O2 sensor
    HO2S 12 - Right Rear O2 sensor
    HO2S 22 - Left Rear O2 sensor
    HSC - High Swirl Combustion
    IAB - Idle Air Bypass
    IAC - Intake Air Control
    IAC - Idle Air Control
    IAS - Idle Air Solenoid
    IAT - Intake Air Temp
    ICM - Ignition Control Module
    IDM - Ignition Diagnostic Monitor
    IFS - Inertia Fuel Shutoff Switch
    IGN - Ignition system or circuit
    IGN GND - Ignition Ground
    IMRC - Intake Manifold Runner Control
    INJ - Injector or Injection
    IS - Inertia Switch (fuel cutoff)
    ISC - Idle Speed Control
    ITS - Idle Tracking Switch
    KAM - Keep Alive Memory
    KAPWR - Keep Alive Power
    KOEO - Key On Engine Off
    KOER - Key On Engine Running
    KS - Knock Sensor
    L - Liter(s)
    LFC - Low Fan Control
    LFP - Low Fuel Pump
    LOS - Limited Operation Strategy
    LUS - Lock-Up Solenoid
    MAF - Mass Air Flow sensor, meter or circuit
    MAF RTN - Mass Air Flow Return
    MAP - Manifold Absolute Pressure
    MA PFI - Mass Air Sequential Port Fuel Injection system
    MAPPA - Manifold Absolute Pressure Per Altitude
    MAT - Manifold Air Temp sensor
    MCU - Microprocessor Control Unit
    MECS - Mazda Engine Control System
    MFI - Multiport Fuel Injection
    MIL - Malfunction Indicator Light
    MLP - Manual Lever Position
    MLPS - Manual Lever Position Sensor
    MLUS - Modulated Lock-Up Solenoid
    MPFI - Multi Port Fuel Injection
    NC - Normally Closed
    NDS - Neutral Drive Switch
    NGS - Neutral Gear Switch
    NPS - Neutral Pressure Switch
    NO - Normally Open
    N2O - Nitrous Oxide
    NOx - Nitrogen Oxides
    NOS - Nitrous Oxide
    O2S - Oxygen Sensor
    OBD - On Board Diagnostics
    OCC - Output Circuit Check
    OCT - Octane
    OCT ADJ - Octane Adjust
    OHC - Over Head Camshaft (engine type)
    OSC - Output State Check
    PA - Pulsed Air Injection
    PAIR - Pulsed Secondary Air Injection
    PATS - Passive anti-theft system
    PCM - Powertrain Control Module
    PCV - Positive Crankcase Ventilation
    PFE - Pressure Feedback EGR sensor or circuit
    PFI - Port Fuel Injection
    PIP - Profile Ignition Pickup
    PLCC - Plastic Leadless Chip Carrier
    PNP - Park / Neutral Position
    PSP - Power Steering Pressure
    PSPS - Power Steering Pressure Switch
    PSOM - Programmable Speedometer/Odometer Module
    PW - Pulse Width
    PWM - Pulse Width Modulated
    PWR - Power
    PWR GND - Power Ground circuit
    RABS - Rear Antilock Brake System
    RM - Relay Module
    RPM - Revolutions Per Minute
    RTN - Return
    RWD - Rear Wheel Drive
    SAW - Spark Angle Word
    SBC - Small Block Chevy
    SC - Super Charged (engine type)
    SD - Speed-Density
    SEFI - Sequential Electronic Fuel Injection
    SFI - Sequential Fuel Injection
    SIG - Signal
    SIG RTN - Signal Return circuit
    SIL - Shift Indicator Light
    SHO - Super High Output
    SPFI - Sequential Port Fuel Injection
    SPOUT - Spark Output Signal from EEC
    SRW - Single Rear Wheel Axle
    SS - Shift Solenoid circuit
    STAR - Self Test Automatic Readout (test equipment)
    ST - Scan Tool
    ST - Self Test
    STI - Self Test Input circuit
    STO - Self Test Output circuit
    TACH - Tachometer
    TAB - Thermactor Air Bypass solenoid valve (AM1)
    TAD - Thermactor Air Diverter solenoid valve (AM2)
    TB - Throttle Body
    TBI - Throttle Body Injection
    TC - Turbocharger
    TCC - Torque Converter Clutch
    TCIL - Transmission Control Indicator Lamp
    TCM - Transmission Control Module
    TCS - Transmission Control Switch
    TDC - Top Dead Center
    TFI - Thick Film Ignition system
    TFT - Transmission Fluid Temperature
    TGS - Top Gear Switch
    THS - Transmission Hydraulic Switch
    TOT - Transmission Oil Temperature
    TP - Throttle Position Sensor
    TPI - Tuned Port Intake
    TPOUT - Throttle Position Output
    TPS - Throttle Position Sensor
    TRD - Transmission Range Drive
    TROD - Transmission Range Overdrive
    TRL - Transmission Range Low
    TRR - Transmission Range Reverse
    TSS - Transmission Speed Sensor
    TTB - Twin Traction Beam
    TTS - Transmission Temperature Switch
    VAF - Vane Air Flow sensor or circuit
    VAF - Volume Air Flow
    VAT - Vane Air Temperature
    VBATT - Vehicle Battery Voltage
    VCRM - Variable Control Relay Module
    VECI - Vehicle Emission Control Information Label
    VM - Vane Meter
    VOM - Analog Volt/Ohm Meter
    VPWR -Vehicle Power supply voltage (regulated 10-14 volts)
    VR - Variable Reluctance
    VREF - Voltage Reference (EEC supplied voltage = 5 volts)
    VRS - Variable Reluctance Sensor
    VSC - Vehicle Speed Control sensor or signal
    VSS - Vehicle Speed Sensor or signal
    WAC - WOT A/C Cut-off switch or circuit
    WOT - Wide Open Throttle
    Ont And Canada PPL The Cookhouse in Dwight
    91 Grand Marq . . . . . . 88 ho wagon (project) . . . . . . 80' Lincoln Mark VI
    Good stuff!!!! Stickified!
      Thanks. i feel like the slum dog millionaire!
      feel free to add, i still have no idea what lopo stands for, the o should go before the p if it meant low output,
        now thats thinking with your dipstick!
        Lets Go Pens!
          Good stuff. Can someone add the webspeak abbreiviations as well?
          1991 LTD P72 351 W Restored Century Police (Ongoing Project) Sergeant Vic.
          It's a dog eat dog world and I'm wearing milk bone underwear.
            Damn. I didn't know most of those. LOL. Very helpful.
              I thought lopo was for low power
                OK, what does HPP stand for?
                Thanks!
                T.A. Malpass 83 LTD Crown Victoria P43
                  Handling and Performance Package
                    Thank you!
                      Forgot a couple ...
                      ADTR = Angry Duck Tofu Racing, a website where whale-body owners go to part with their money
                      J-mod = valvebody modifications to make your 4L60E bark the tires.
                        I see a few around here that are not addressed in this post.
                        civi (it is used when describing sway bars)
                        Mang (everyone is calling each other that)
                        P72 , P79 (describing a model of car)
                        Aero / Whale ( I get that it is the newer cars.. but why these names)
                        Thanks for hosting my lack of knowledge.
                        Mike J.
                        1990 Country Squire LX .... Rolling around 220k miles Man is she Sweet to me.
                        1976 Lincoln Continental .... 55k miles and loaded with Smiles !!!
                        1990 LTD Crown Victoria Wagon .... "Fresh" project
                        A parking lot \ barn full of Non-GMN related vehicles.
                          Mike J.
                          Civi - Civilian Vehicles
                          Mang - Another word for man
                          P72, P71, etc - Ford's designations for each model, for example P71 would be a Police interceptor
                          Aero - 1992-1997 ( I think?)
                          Whale - 1998+ ('')
                          '97 Cadillac Catera - 3.0 DOHC V6, 75k
                          Soon... Any '95+ Panther!
                          CLICK ME! Parts For Sale, SUPER CHEAP!!!
                            OK so Aero is '92-'97
                            and Whale is '98+
                            So I assume Box is pre-'92???
                            Where do the aero and whale names come from?
                            If this all is true then a driver of a '90 TownCar would go to the box section since it has a 302 and go to the Aero section for body issues. Does this sound right?
                              aero comes from the "aerodynamic" design. I'm not sure about the whale. box is 79-91. 78 and older are referred to as barges due to being that much bigger.
                              Not sure about the Lincoln stuff.
