Rebuliding the lo-po
    You know, sometimes the machine shop can get you a better deal on the parts. Sometimes...
      Are you going to reuse the lopo cam? I would go ahead and do a cam swap while the motor is apart, find an Explorer cam. I really like the Lunati Vodoo cam in my Silverado.
        Originally posted by Pesty351 View Post
        Umm.. Might be a dumb ? but were 84's roller blocks or not? I thought they weren't but if that is the case whats with the xxx? BTW the machine shop wants ~650 to refresh the shortblock.
        The roller blocks didn't start showing up until 1985.
          xxx has no significance I'm aware of. If you have two raised bosses in the middle of the lifter valley, then its a roller block. No boss, no roller. And 85 was indeed the magic year.
            Ok I was apparently miss informed about the xxx thing. As far as cam selection I going to go with something a little better suited for a small car.
            1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
              The local machine shop with a good reputation told me ~$650 for a short block rebuild. Do you all figure that's a decent price or should I keep looking?
                Is that all the machine work plus assembly, or the machine work plus the engine kit, and you put it together? Seems to me I paid around 600-650 for the machine work and the engine kit, and I put it together myself. That was including a bore job and a set of pistons though.
                  I paid $175 to have my crank turned .010 and $250 to have the shortblock assembled here in Raleigh, NC. Parts were another story...
                    Thats parts, machine work, and assy.
                      I'd say thats not too bad then. Including new pistons, or would those be extra if needed?
                        Extra if needed. I'm hoping with the way the walls look that they don't need replaced.
                          Ok the shop cut there price a bit 750 with new pistons and everything should be done this week. Wahoo!
                            It's done now I just need to put it the rest of the way together. It ended up .30 over on the pistons and 10 on the crank. All I have left is to pick a cam and to figure out what push rods to use.
                              Should be a decent running little motor! You going to put the AOD in there too? That mav would be a cool cruiser then!
                                very nice!
