Originally posted by 87_crown_vic
View Post
Door Speakers
No. Just go into the trunk and release the rubber band thing holding them.~David~
Hell, I didn't even know we had dash speakers. I can't see or hear 'em!sigpic
Originally posted by mikeroc283 View PostDid the rear decks and the doors. I have this set of alpines that are 4 inch. What size are the dash speakers?
How would a person normally go about driving both dash and door speakers from a "normal" headunit? (yeah, you can tell I'm a real car-audio tech-head!)2012 Mazda5 Touring | Finally working on the LTD again!
So just tied the dash and door speakers together and ran both to the front outputs on the stereo? I guess the total impedance shouldn't go up too much with them wired in parallel .... of course, I'm sort of afraid to do that since early experiments with a 4 Ohm boombox with removable speakers led to lots of buzzing, sqeals, and other weirdness in the old car speakers I tried to add in parallel.2012 Mazda5 Touring | Finally working on the LTD again!
i have dash and door speakers wired to the front channels of a 4 channel amp......works great.......not sure about just off the head unit, i usually run amps
Originally posted by 1990LTD View PostHell, I didn't even know we had dash speakers. I can't see or hear 'em!Originally posted by gadget73There is nothing more permanent than a temporary fix.
Originally posted by Lincolnmania View Posti have dash and door speakers wired to the front channels of a 4 channel amp......works great.......not sure about just off the head unit, i usually run amps~David~
Running two speakers together off one channel cuts the ohm load in half, most amps can handle this but its a good way to fry a head unit (unless its specifically designed to handle a 2ohm load) if you crank it too loud.
It doesn't matter what kind of alternator you have, its not going to change how many speakers your head unit can safely power.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
That is good to know. I used two different headunits by running two speakers together and everything was fine. I am now safe with the amp.~David~
If you don't max out the head unit with the 'super bass' on it probably wont hurt anything... it would just make it 'clip' (sound bad) sooner on the dial if you crank it.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
