I was cruising around with my friends last night..and I began to smell gas....So i pulled over checked under the hood but eventually found the problem on the fuel line that rides the frame rail...it was dripping pretty fast and was sprayed all over the joint ...The line was leaking about 7inches from the fuel filter....The only thing i can think of what happened is..yesterday I had the car hand washed and the underframe preassure washed..but that was at 6 and it didnt start leaking untill 1230 that night....ugh...and now the mechanic I usually take it too dosent want to touch it...so I called my friend at the stealership and there going to look at it tommarrow and maybe splice it, but they have to look at it first...any advice mangs.... I appreciate the help
Fuel Line Failure...HELP!!!!
It should be a relatively simple fix. No more difficult than brake lines. If your only other option is the dealer, I'd save a couple hundred and DIY.
mine busted once when replacing the fuel filter. i temporarily used rubber fuel line and some hose claps till i got some real fuel line and spliced it in. that was a horrible day.~David~
It sounds like its in a an easy spot to splice in a new line... being up north they probably do them all the time. Your usual shop sounds like they are either scared of a challenging job or have too much gravy work to trifle with a 'challenge'...Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by 85crownHPP View PostIt sounds like its in a an easy spot to splice in a new line... being up north they probably do them all the time. Your usual shop sounds like they are either scared of a challenging job or have too much gravy work to trifle with a 'challenge'...~David~
Originally posted by 87gtVIC View Postthey are probably scared because every time i touched mine more and more line would break lol.
If the line is bad enough that pressure washing it makes it brake, its all shot. Replace it now before it breaks and sprays on the exhaust or something.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostIf the line is bad enough that pressure washing it makes it brake, its all shot. Replace it now before it breaks and sprays on the exhaust or something.'79 Continental Town Car
'90 Crown Victoria LTD
'94 Crown Victoria
You can buy fuel line in bulk just like brake line... you dont need pre-made pieces... any line can be fixed. They are just getting you ready for the huge bill, because yes things like to break during the repair. Thats why you usually wind up replacing everything!Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
+10 on the above. A roll of aluminum line is around $25 from Summit, and is very easy to work with. All you'll need is a double-flare tool, a tubing bender (maybe), and misc. fittings (usually available at NAPA) to adapt to the stock high-pressure rubber lines.2012 Mazda5 Touring | Finally working on the LTD again!
5/16" steel line in bulk is what you need
5/16" high pressure fuel hose
high pressure fuel clamps
you can save the fittings, just cut the plastic fuel line off of the fittings
Originally posted by 1987cp View Post+10 on the above. A roll of aluminum line is around $25 from Summit, and is very easy to work with. All you'll need is a double-flare tool, a tubing bender (maybe), and misc. fittings (usually available at NAPA) to adapt to the stock high-pressure rubber lines.
Originally posted by Lincolnmania View Post5/16" steel line in bulk is what you need
Last edited by 1987cp; 05-04-2009, 09:35 AM.2012 Mazda5 Touring | Finally working on the LTD again!
nah i use a more primitive method with the flaring tool and the high pressure fuel hose and clamps......you dont want to use regular hose clamps here mangs.
i will be replacing fuel lines and brake lines this week, if you and i are lucky, someone might hand me tools and take pictures......we tried to start the yob sunday evening, but my floor jack shit the bed and gadget and i spent all night fixing it
