Page 3 of 3 FirstFirst 123
Results 41 to 56 of 56
Thread: Alternator wiring diagrams: 1G, 2G, and 3G
  1. #41
    22,682
    "should" yes. If not... there's a problem. Check the wire harness connections on the driver fender if there's not 12V there. I think there's one or 2 harnesses inline to the alt.
  2. #42
    2,042
    Hahahahahaha, sorry guys for all the posts... figured it out.
    So, once I'd rechecked my wiring for the dozenth time, I mean come ON! The 3g upgrade is not rocket science, and I was getting really frustrated.
    Your posts and photos confirmed I'd definitely had it correct.
    So finally I take the alternator to pepboys and have it retested. I'd tested it at salvos last month, what could possibly have changed sitting in a bin...
    And as it goes down the test, the results for voltage: FAIL regulator: FAIL diodes: FAIL.
    Heh, well that explains that.
    As I walk back to the car, planning my next trip to the junkyard but pleased I'd figured it out, I notice something.
    I'd gone ahead and replaced the brushes for good measure.
    To install them, there's a pin that holds back the springs. I'd sworn I'd removed it, but i think I switched regulators from a rebuilt one back to motorcraft at one point.
    It was still in there.
    The brushes never had contact with the alternator!
    I take it back in to pepboys, borrow a pair of pliers, pull the pin, test it, passes: put it on the car, and 15V. Whew!
  3. #43
    Member hypostang's Avatar
    Feb 2011
    Maryville Tn.
    404
    Glad you got it figured out ..and I promise i did not chuckle
    1988 Signature Series Town Car
  4. #44
    22,682
    rolling on the floor laughing however...
    glad you got it sorted. at least it ended up being simple.
  5. #45
    2,042
    oh, feel free to. I did-- what else can you do after wasting hours uninstalling, rewiring, reinstalling an alternator only to find out it was a stupid little pin I'd forgotten to pull?
  6. #46
    Mazda5: the Anti-Van! 1987cp's Avatar
    Dec 2006
    Michigan-ish
    5,887
    Quote Originally Posted by BerniniCaCO3 View Post
    Ooooh. No wonder it tested good at the 'yard and then subsequently refused to work! I would never have thought of that, as I've never replaced alternator brushes - I've always just taken a known-working alternator and tossed it on the car.
  7. #47
    Go take a bath! Go milk your goat! Piece-it pete's Avatar
    Mar 2009
    Cleveland. We rock.
    3,936
    I've got an 85 which is I believe a 1G. There is still no difference in the swap, and I cut out the external regulator, correct? Also Gadget mentioned the choke heater which I see is the W/BK wire, I can just splice the heater wire into that?
    Pete
  8. #48
    Mar 2009
    Cleveland. We rock.
    3,936
    Oh and I should have to cut and join two wires at the Regulator for 'hot in run' right? Anyone know which ones? And just abandon the other two?
    Pete
  9. #49
    Mar 2009
    Cleveland. We rock.
    3,936
    Quote Originally Posted by Piece-it pete View Post
    Pete
    Oh I see, I can just pick a wire
    Pete
  10. #50
    Mar 2009
    Cleveland. We rock.
    3,936
    Alt conversion done! 1G and external regulator ripped out, 3G in. The minor wire mods were easy but did take a little thought. Not all wire colors on the diagram were correct (I think, my compartment is dirty. White/black looked quite yellow) but heck it's only a couple wires. Used the 98+ F150 wire mentioned. That put the new main fuse right at the brace for the AC compressor, zip tie there, picked up a 32" battery cable, cut off the clamp and ran it over to the battery, main fuse to hose for emmisions crap on fender, ziptie, then to battery. The stock belt was difficult to get on (the 3G doesn't go over to 'loose' as far) but once over the lip was fine. Also I did have to ream out the bottom bolt hole in the casing just a little. As Gadget mentioned, on a CFI you need to tap the choke heater wire into the white/black jumper on the 3G.
    Results? I think the car runs better than it did when the 1G was working. And surprisingly (or maybe not?) the stereo sounds much better particularly at higher levels. Bass is obviously tighter and clearer.
    Many thanks to the fine gentlemen here at GMN.
    Pete
  11. #51
    Presidential Ride L1011tristar17's Avatar
    Sep 2012
    Charlotte, NC
    899
    I'm trying to install the 3G alternator, but the lower bolt from the original doesn't fit the new alternator, it's too big. Has anyone else encountered this problem? I don't know if I need a smaller bolt or to drill out and make the hole bigger.
    1989 Lincoln Town Car 249k miles, current project car
    2018 Toyota Tacoma bone stock, daily driver
  12. #52
    22,682
    I had to drill out the hole on the one I put on my 88 for the long bolt to fit. I also had to use a nut/bolt setup on the top since the used one was not threaded.
  13. #53
    Sep 2012
    Charlotte, NC
    899
    ^ That's what I ended up doing as well.
  14. #54
    Member fmansfield444's Avatar
    Apr 2012
    Northern KY
    677
    I'm about to do this to my car tomorrow. I got the 3G and all the wiring and fuse. Only question is should I keep the 3g's pulley or put my 1g's smaller pulley on the 3G? I've read though some threads and couldn't find much info.
  15. #55
    22,682
    keep the 3g's pulley. it works that much better and the lower RPM will save the bearings in the long run.
  16. #56
    Hi, Im looking for the wiring diagram for the 81 crown vic and by any chance the wiring diagram for the 88 any one that can help, thanks in advance.
Tags for this Thread
