Stuff I am selling at Scottfest.
    I figured id try and get this up early to see if there is any interest and just give everyone that will be attending a heads up.
    For Sale
    Scottfest 2009
    1.Custom dual A-pillar gauge pod for boxed Crown Victoria and Grand Marquis. $30
    2.6 Ford turbines and tires (4: 225 70 15, and 2: 235 75 15) with two sets of centercaps $250 **
    3.Ford Country Squire and Mercury Colony Park, boxed panther lifting springs. $50
    4.2 (two) Ford steelie Hub caps (believe 15”) $7 each
    5.4 (four) 2005 V6 Mustang Spinner center caps $50
    6.34 ½ inches of Original Ford Dew wipe material. Just enough for 1 (one) Tudor door or perfect to cut down for a 4 (four) door vehicle Perfect condition. $12
    7.2 (two) 13 inch stripes of JCWhitneys' Fairchild Industries style 43 replacement dew wipe material. Can combine to cover one four door window dew wipe. $5 for both
    8.3 (three) Ford Explorer (raised) Ford center caps with 5 (five) shouldered lugs a piece. $17 each
    9.6 (six) shouldered lug nuts $1 each, 1 (one) set of McGard Ford original locking lugs $8, and 1 (one) set of chromed McGard locking lug nuts (a bit beat up but comes in original packaging with identification number) $8
    10.Flashing (Fake Alarm) LED kit. Flashes while car is off and not on. $20
    11.3 (three) 12 volt plugs (on/off), 1 (one) 12 volt plug, couple switch plates, 3 (three) 2 1/16 gauge plates, 4 (four) various switches and a pair of blue gel caps. $1 each
    12.Working neon blue flames(pair), Ford Flame oval, 2 (two) toggle switches, and Silver Ford emblem. $5 each skull door lock knobs $3
    13.Tan Door storage rack with cup holder. Has slight crack. (From JcWhitney http://www.jcwhitney.com/DOOR-STORAG...1528_10101.jcw) $4
    * Must inquire about the wheels beforehand for i will not bring them on the trip if no one is interested.
    Your choice of $1 item with purchase of any item
    the cvpi caps are $17... each?
      Yea or $12 without the lugs. These particular caps have 5 shouldered receptors on its backside.
      I am slightly negotiable on mostly everything if you are really interested in something i will likely help you out within reason. Some of the things I am selling are my fathers.
        UPDATE.
          1. All CVPI caps reduced to $10
          2. the set of 6 turbines with tires reduced to $200
          3. flashing fake alarm LED kit reduced to $10
          4. locking lug sets are $5 a piece
          5. Dual a pillar gauge pod is now $25
          6. steelie hubcaps are now $5 each
          7. original FORD dew wipe material (perfect condition) $10
          8. springs reduced to $45
          If I can get that dual pillar thingy to fit on the Towncar without much fuss, I want it. Bring it down if someone hasn't bought it by then.
            If you like the fit, its yours.
            I dont know what you have in mind but the actual pod is siliconed firmly in place so we may have to work around that.
              dave i will take one one the mcgard looking sets the shinny one lol
                What size hexes are on your shoulder lugnuts? I have several 3/4 and several 13/16, both sets unfortunately incomplete at present.
                  You got it. Thats the "bit beat up" set but come in the original packaging with I.D. number and all.
                  Each one i have is 3/4"
                    :bump:
                      Its siliconed firmly to what, the Vic trim? Thats a bit of a problem since I can't use Vic trim parts. I mostly want to see if the pod itself can be made to fit on Towncar A pillar trim without much fuss.
                        i dont need the rims but i do need tires badley.
                          Yes it is siliconed firmly to the vic trim as a unit. But if you see that the Town car a pillar (center portion NOT ends) matches up to the Vic pillar you can easily take it off by sliding some fishing line through to dislodge the silicone.
                          Pm'd
                            Bump....Scottfest is coming quick! Express your interests.
                              Final :bump:
                              ****Let me know if you want something*****
                              ****I will not be bringing the 2 Ford Steelie caps or the 4 2005 V6 Mustang spinners and the turbines with all of the caps if nobody will be purchasing them.****
                              EDIT: Make offers on lifting springs.
