Originally posted by visionmercury
View Post
let the stroker live
Originally posted by 1987cp View PostThere are specific blocks for use with a dry-sump system? Does it basically just use different oil inlet routing?
Check out a Ford Motorsport catalog sometime, and look at the blocks available. It seems like there were a few 8.2" deck units with dry-sump oiling.
Originally posted by visionmercury View Posta 376 ci would be pretty bad ass tho , but a supercharged wagon i think would be cooler
when i win the lottery i will deffinitly be supercharging my wagon'88 Colony Park, white with wood grain contact paper, K code axle, hose pliers on heater hoses, factory duals, big plans in the future...
'83 Toyota 4x4, 31x10.50 15, could use a new carb, custom humidifying holes in the roof, mud based paint...
My auto machinist is currently working on a 410" windsor stroker for a customer's '67 Mustang. It uses an aluminum block from World Products, which he purchased from a dealer on Long Island. He has returned the block twice because the cam bore alignment has been "unusable" in his opinion. World has obliged him on both occasions, which means there had to have been some merit to his claims.
This guy does alot of really high end stuff (from trophy truck to sprint car engines), so I tend to believe he knows what he's doing. He said most aftermarket blocks require alot of work to make ready. They are not simply ready to go when its delivered to your house.
Congrats on the purchase, but be advised of this.
I'd rather unload the aluminum block, and build yourself a decent iron bottom end.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
im planing on using a d-1sc procharger. ill probley buy a mustang kit and modify it to work . i can run differant piping threw itsigpicTHE H.I.D MASTER
87 mercury grand marquis
88 crown vic lx
89 mercury colony park ls (sold)
89 mercury grand marquis (sold)
00 ford crown vic lx hpp
03 mercury marauder aka punisher (sold )
Came across this dyno sheet today, and thought it may be pertinent to this thread so i figured id post it. Should be a rough ballpark of where you could be with this.
This is a 347
Eagle forged 4340 crank
eagle H beam rods
JE flat top pistons
10 to 1 compression
Camshaft innovations cam shaft and valve train.
AFR 185 heads untouched
Edelbrock rpm 2 intake
75 mm throttle body
with a small procharger p600b at 10 psi
Due to the compression the timing is at19 degre max
all on 91 octane, also.
Yes, that is rwhp.
