Originally posted by 88grandmarq
View Post
Twin turbo 306 Towncar
Jobs are overrated. Also, used parts, especially stuff like this, can be questionable. I'd really want to inspect it in person for something like that, turbos are probably not the cheapest thing to rebuild if there is major damage. My last "deal" purchase turned out to involve a total of 6 bent valves, so you have to take descriptions with a grain of salt sometimes.86 Lincoln Town Car (Galactica).
Originally posted by 89LincolnTWNcar View PostI just retracted my bid because the kid selling them posted a revision to his ebay listing saying a chunk of piston went through each one :yuck: I'll be looking for maybe a bit of a bigger turbo set than .50mm
I *had* thought the rule of thumb with turbos on a street car was like carburetors; that is, run the smallest one that's sufficient for your needs?2012 Mazda5 Touring | Finally working on the LTD again!
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Thain's right, they ain't cheap to rebuild, but if you end up with something that needs rebuilding, you can always ship them to me and I'll build 'em up for the cost of the rebuild kit. (I do it for a living. )
Originally posted by Velvet Elvis View PostI would imagine max boost at 2500 on a 5.0 with those...Friggin .48 housing does that on a stock 2.3L...SVO's can cruise on the highway without spooling the turbos. I would use .63's, I got better milage and more power on mine with the 63 exhaust housing.
'90 LX 5.0 mustang
Big plans
I wrote down all the stuff that needs to happen before the turbos go on.
195* thermo - bought
Taurus fan - bought
proper tranny cooler line routing - need to do
3.55 locking K-code with disc brakes - bought
cargo coils - bought
big brakes and front end rebuild (so I can stop the damn thing lol) - don't got
AEM Wideband (so I don't blow shiz up) - don't got
Mass air conversion - don't got
Tweecer - don't got1990 LTD Crown Vic w/ dead 5.0
1984 Pontiac 6000 cammed 2.5L Iron Duke
1986 F-150 300 6cyl 5spd.
1994 Crown Vic... Free, bad trans?
Interesting ideas here. I had a turbo idea for my future as well, but my only problem would be the underhood placement of the turbos, intercooler, and all the piping...
Thoughts?sigpic
https://www.facebook.com/jason.baker.1614
1985 P43 Crown Vic, "Lightning Interceptor". Project is back on!
1987 P72 Crown Vic, EFI 351W (not my conversion), rusty and crusty parts car.
2006 Ford Fusion, 30MPG, premium sound, daily driver, 200K miles and still going.
2011 Ford Fucus, 36MPG, Sync, wifey / baby mobile.
Originally posted by Grandpaslincoln View PostI've seen guys put the turbo under the car because there was no room under the hood.sigpic
Aside from the ground clearance problems it would introduce, I'd have to figure they'd be less efficient since you have less exhaust velocity the further back you go. I would move stuff out of the way before hanging an expensive turbo under the car where it could get bonked on some oversized speedbump.86 Lincoln Town Car (Galactica).
I think they get around the exhaust velocity problem in longer exhaust systems by using a wrap to keep EGT's up.
My main worry would be lag, not it getting bumped with the space and clearance on a Towncar.
There's plenty of room under the hood! Even more if you scrap the AC, relocate the battery, junk the old reservoir tanks... if they can stuff two in a supra...Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
I'll probably mount them behind the front bumper somewhere, or where the AC used to be and intake is now, theres plenty of room.
