How's the car run now? Probably moves pretty good...
Twin turbo 306 Towncar
Originally posted by Grand_Marquis_GT View PostHow's the car run now? Probably moves pretty good...1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Originally posted by Heretic View PostInteresting ideas here. I had a turbo idea for my future as well, but my only problem would be the underhood placement of the turbos, intercooler, and all the piping...
Thoughts?Builder/Owner of Badass Panther Wagons
Originally posted by 89LincolnTWNcar View PostOh its pretty good, needs more gear down low though. 0-60 beat a 5 speed 2002 Mustang 3.8L by a car length. Hung with an s2000 1st gear pull 20-60 then he pulled away.Builder/Owner of Badass Panther Wagons
Not a whole lot going on, still rabblerousing the cash and looking in the yards for mass air stuff.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Originally posted by 89LincolnTWNcar View PostNot a whole lot going on, still rabblerousing the cash and looking in the yards for mass air stuff.1983 Grand Marquis 2Dr Sedan "Mercules"
Originally posted by Grand_Marquis_GT View PostI got an 80mm Mark 8 MAF I can sell you cheap...1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
any MAF meter outside of the stock Mustang MAF will need to be tuned to run correctly.
stock mark 8 meters are calibrated for 24lb injectors, I have one left over from the MAF conversion I did.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
I've got a spare 80mm with harness I picked up at the junkyard for 5 bucks..
MAF's aren't "calibrated" for injectors. ECU's are calibrated for injectors and MAF's.Builder/Owner of Badass Panther Wagons
Originally posted by Titanius Anglesmith View PostLMAO no room....A powerstroke IC fits perfectly, a huge turbo (holset H1C) fits without any problems...Hell, even the powerstroke IC tubes line up to the panther TB!sigpic
https://www.facebook.com/jason.baker.1614
1985 P43 Crown Vic, "Lightning Interceptor". Project is back on!
1987 P72 Crown Vic, EFI 351W (not my conversion), rusty and crusty parts car.
2006 Ford Fusion, 30MPG, premium sound, daily driver, 200K miles and still going.
2011 Ford Fucus, 36MPG, Sync, wifey / baby mobile.
Originally posted by Titanius Anglesmith View PostMAF's aren't "calibrated" for injectors. ECU's are calibrated for injectors and MAF's.
Yes, I know this... it was just easier to explain the other way.
Regardless, the Mustang ECM wont be calibrated for the 80mm MAF or the 24lb injector, so it doesnt really matter. you need it tuned anyway.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Originally posted by Heretic View PostPics?Builder/Owner of Badass Panther Wagons
Met a friend of a friend today who does turbo 5.0 Fox's, he's got like 3 of them. He also works for Ford's SVTeam. This is going to happen :evil:1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Here a video of Anabelle doing 0-80mph. Had to turn to get onto the curved on-ramp so videos not so great...but you can hear the engine roar. If you go roughly by the video, I floor it right about 7seconds in and get to 60 at about 14 seconds so maybe 0-60 in about 7 seconds? IDK for sure.
http://www.youtube.com/watch?v=RS7ZKdo3SRkLast edited by 89LincolnTWNcar; 10-02-2009, 12:42 AM.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
