introduction and a few questions
    hi my name is chris and i am an allignment tech in MA. i recently purchased a 1999 grand maquis gs w/ 65,000 miles for $1200 dollars. I do have a basic a car knowledge, but it doesnt really go past routine service. ive posted these questions in other forms but didnt get answers probally becasue there on stickys allready.
    question #1
    i recently put a set of rims on the car, tire dimensions are, front 245/35R20 and the rears are 285/30R20, i dont have a rubbing problem i just dont like the way the car stands. here is a picture
    i would like to lower it 1.5 inches front and rear but cannot find parts to do so i would like anyones advice on this because i know the car would look much better that way.
    question #2
    im interested in in a 3.73:1 ring and pinion swap, i have percission trac on my car and need it to be active because i hydroplane like crazy from the width of my rear wheels, if i swap the gears and change to a stronger police interceptor drive shaft will i need further parts for this system to work correctly?
    welcome to gmn chris!
    you might want to use speedway motors circle track springs to lower the car..........i mainly work on the boxes, so i'm not 100% sure how much they will lower the car
    you can install 3.73 gears and the pi driveshaft, but you will need a sct tuner to correct the speedo or you wont be able to go over 90 mph with the 3.73's
      Nice Whale!! Welcome to GMN
      '79 Continental Town Car
      '90 Crown Victoria LTD
      '94 Crown Victoria
        thanx lincolnmania, and lincolnlover79
        Suspension Question Update
        i found a sticky that gave alot of info but it says for 91 and back, but is that for the calculated 1 inch drop or the parts wont fit? What changes to the suspenision were made after 91?
        Here are links to the parts im looking at
        front = http://www.speedwaymotors.com/Street...rings,166.html
        rear = http://www.speedwaymotors.com/Tru-Co...rings,168.html
        if these do fit i will be satisfied for around an inch because even tho the od on my old and new tire/rim is very close it looks like its sittin a little to high.
        if someone knows if theses will work on my 99 gm please let me know, or if they dont and you could point me a little closer in the right direction that would be great.
          you could go old school and cut the springs, but I like to keep the geometry stock to avoid problems.
            Nice ride!
              Nice.
              And yay, someone who can actually align one of these damn cars.
                Too bad you're nowhere near Michigan, if your alignment skillz are any good.
                  ive alligned many panthers because my shop takes in local police department allignments, and all sorts of undercover cars "its quite surprisng when you goto hit a horn and all the sirens start going off. " actually off topic but one of the most interesting vechicles that came into my shop was a sting van, it was set up like a plumbing truck, had like 5 hd camcorders with a periscope, i had to test the battery, and when i opened the hood the guy who brought it was like no the other batterys and i looked at him like ???? he opened the back and i swear it was just like out of a movie i wish i took a picture but i dont think he would have appreciated it.
                  Also i was trying to avoid cutting springs because from what i heard u have to cut one full coil off and im looking for such a small drop and i know that will just lead to problems
                    That sounds awfully nifty about that van!
                    On my '87 wagon, I cut a half coil. Made for a nice handling improvement without dropping too much, and I was ultimately able to get it aligned OK afterwards.
                      Welcome!
