sea foam
    sea foam
    good or waste of money?
    Cleaned my 92 out nicely....
    Brian
    sigpic87 LTD Wagon
      Good stuff. You can use it regularly as fuel injector cleaner or do the cleaning with it. Just pour it down a vaccum line or prefibly your PCV line until the car dies out out...wait 5-10 mins start the car up and watch the smoke show.
      P.S. I just dump the whole bottle in........
        I love seafoam but it's so fucking pricy. it's like almost 9.00 bucks a bottle for 16 oz
          OReily's is a little less if you have one close and they sell it by the gallon which you really save money with.
          I've used it for years in my cars and bikes. Great stuff.
            i was told to get a oil change after using it. the guy said it makes the oil thick
              it doesnt clean intake ports on the uppre or lower intake to well. best to tear them down and manually scrub that stuff than do an oil change to keep carb cleaner from washing out main bearings... i have photo evidence after cleaning... best to clean it manually
              Addicted to 86-87 Panthers
                Don't do it.....if you must don't put it in the oil....you have been warned X_X
                  Put it in the fuel tank and in the brake vac line. I would not put it in the oil.
                  89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
                    I've found water in the PVC line works wonders as well. Cleared my Check engine light in the GM.
                      Don't dump ANY engine flush in the oil for that matter. But yes, Sea Foam works great if done right. Oil change and new plugs can't hurt after.
                      1990 LTD Crown Vic w/ dead 5.0
                      1984 Pontiac 6000 cammed 2.5L Iron Duke
                      1986 F-150 300 6cyl 5spd.
                      1994 Crown Vic... Free, bad trans?
                        Water will clean it out. Acts like a steam cleaner inside the engine.
                          seafoam is good shit, i dont recommend puttin it in the oil though.. I use the pcv line.
                            b12 chemtool does the same thing.....only 3 bucks a can
                              I don't think they sell Seafom in Canada, so I bought Canadian Tire "Carburetor and Combustion Chamber Cleaner" in a smallish black bottle. Does anyone know if this stuff works as well as seafoam? The instructions are similar.
