It started like this: Originally, when I started my car, it would fire and then immediately stall, and only if I immediately put it into gear would it continue to run. The last time this happened to me it turned out to be a vacuum leak. So I did a little investigating, and sure enough, the PCV Grommet with the valve in it had worked its way out of the block. Fixed that, and now we have this:
Whenever I start the car and the motor's cold, it will rev up to ~1200, and then act like it wants to die, and at about ~200 rpm, it will catch itself and rev back up to ~1200, and then the cycle will repeat itself. When in gear, it will move back and forth between 500 and 800 rpm, resulting in the car pulling against the brakes when I sit at a stoplight. Once you get rolling, above 1000 rpm or so, it runs and pulls just fine.
I have taken the propane torch and waved it all over the entire engine bay, trying to find more vacuum leaks, to no avail. I also got code 34, but that was the only one.
Here's what I've done so far:
Wires, cap, and rotor are all about 6-8months old. Plugs are about two years old.
Air injection system is disconnected, with a wicked exhaust leak coming out the tube from the back of the head. No idea why I didn't get codes for that system, but maybe it's because the solenoids are still there, but the vacuum side is capped.
Any thoughts?
- New IAC
- New TPS
- Inspected EGR valve, and it appeared to operate properly when I applied vacuum with a hand pump
- Replaced EGR vacuum solenoid, since it didn't pass the test outlined in the Chilton's manual.
Any thoughts?
