HO Conversion - Mike's Tips and FAQ
This is a sticky topic.
    Originally posted by rab View Post
    what does the comp ratio come out to be,with the ho conversion on a lopo 5.0
    anyone have a idea?
      between 8.7 and 9...
        Originally posted by Lincolnmania View Post
        lifters, pushrods, rocker arms are all the same yes
        ... though one should always check to make sure lifter preload is correct (one of my engines was OK, the other one I finally bought some longer pushrods to quiet some of the clatter).
        I take it, though, most guys are able to get away without getting longer pushrods?
          Can't use a roller camshaft in an 84 block unless you buy those expensive link bar retrofit lifters. Can't use flat lifters on a roller camshaft either.
          Very confused. So can one use stock lifters from lets say an 87 crown vic on a highoutput cam from an 86 and up high output car, or explorer?
            The rockers are all the same from about 1978 onward
            roller lifters are the same from 86 onward
            pushrods are basically the same for all roller motors, but lengths might be somewhat different depending on application
            There are several block castings, but the only thing thats really relavent is that 86+ car engines are roller motors, and 84- are flat tappet motors. 85 is a mixed bag, so we just won't get into that.
            So in short, yes you can use an 86 HO cam with your 87 lopo roller lifters. Both motors have roller cams, so its not an issue. If you were trying to use 1984 flat tappet lifters with an 86 roller cam, it would be a huge disaster.
              Ah ok ok. My dad was insisting that my car does not have roller lifters. I just needed to have that cleared up!
                Ok guys I'm slowly learning about all this engine talk and such, I catch on quick, so don't think I'm going to ask a million and one questions (I'm no N00B) lol
                So I have the 302 in my Town Car...
                If I get the following parts
                E7 Heads
                HO computer (ECM)
                HO intake
                HO Throttle body
                and and HO cam
                aftermarket shortie headers
                and adjust the timing
                Edit: What about headers?
                I have dual exhaust now, so redo and get an H-pipe with a catback
                I will have an HO town car? Around what would the power increase be?
                1990 Lincoln Town Car 5.0 @ 125K /// 2007 Hyundai Sonata 3.3 @ 29K
                  You will need 19lb injectors as well as a bored out egr spacer. And then you will just have all of the parts for a High Output conversion. Once you install then you have a High Output Town Car.
                  Just get some headers that are meant for Fox bodied Mustangs. They will be fine, the you will need a Fox bodied H-pipe to connect to the headers, then i recommend heading to an exhaust shop and getting the rest done up with some good piping. Or you can figure out how to adapt the existing exhaust to the new H-Pipe
                    anything wrong with, or more difficult, involved etc. etc. with using a mustang mass air ecm and wiring, maf sensor, setup verses the speed density one? any disadvantages?
                      The wiring isn't too bad, but it's kinda messy and no clean looking MAF mounting solution. (without some expensive parts and tuning) SD you can keep integrated cruise on later model boxes too.
                        can i do this to a 1983 Grand Marquis with electronic fuel injection 351 windsor.
                          I didn't think there were any EFI 351s except in trucks
                            he's got a weirdo CFI-converted 351.
                            You can't swap the 302 HO top end onto a 351, no. A 302 intake is not wide enough for a 351 block. You may be able to swap a 351 truck EFI intake onto it, and that'd certainly be a big power gain. I think you need a cowl hood though, and it'd def be more involved than a regular HO swap.
                              you would need a cowl for a truck manifold (ive looked into it already). If you have the cheese and your are fortunate enought to find one, a stock F150 Lightning 351 manifold fits under the stock hood with no problems. Its just finding one, and then when you find one, paying for it.
                              Parts Car (Scrapped ) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
                              New Project: Vicky II - 1981 Ford LTD: 61,XXX miles, virtually rust free. Currently For Sale
                                Got one. ; ) Can I has cookie?
                                '90 LX 5.0 mustang
                                Big plans
