HO Conversion - Mike's Tips and FAQ
This is a sticky topic.
    Originally posted by MattsGrandMarquis View Post
    can i do this to a 1983 Grand Marquis with electronic fuel injection 351 windsor.
    yea it can be done.......gmn member heretic has a lightning 351 motor in his box vic.......you have to use the lightning or the explorer upper intake........need a lightning 351 or gt40 marine lower intake
      I believe a efi edelbrock super vic with a medium hieght elbow will also fit under the stock hood, as it only measures 1/2'' taller than a lightning intake. But it may be a little much for most people.
      '90 LX 5.0 mustang
      Big plans
        I think it's more that few GMNers want/can spend the bucks for an aftermarket EFI intake, and want stuff that will run OK with one stock ECM calibration or other. If I were to build a EFI motor, I'd be looking at the elbow concept pretty hard.
          Well I can get a super Vic, throttle body elbow, and super Vic specific fuel rails for less money than I paid for my lightning intake, so in theory it is a cheaper option than a lightning intake.
          '90 LX 5.0 mustang
          Big plans
            hmmm....
            I do know big TBs are pricy, though.
              True true, I believe an accufab 90mm is around $290.
              '90 LX 5.0 mustang
              Big plans
                what are the numbers for the desirable ECUs with cruise control from Tbirds and Lincolns? I am seeing a few options on an inventory list (ID F1MF-GA , ID F2MF-PA , etc etc)
                  Mark VII HO ECM (they did have LOPO's too)
                  There are 2 different ones, D9S is one, I forget what the other one is but.....:smirk:
                  Former panther owner
                  1981 CV 351 4bbl
                  1991 CV 302 EFI
                    What hp/tq gains does the full ho swap net? Stock ho vs stock lopo vs lopo/ho intake
                      question:
                      I just started with an HO block and intake, and moved all of my lopo stuff on to it. Never had a donor longblock.
                      Is there any reason why I would need the HO IAC, throttle position sensor, egr valve, or other HO sensors, or are the lopo ones the same/ operate in the same voltage ranges?
                        the only actuators that are any different are the fuel injectors. sensors are the same
                          Like to ask..What about rods?what are the differences between all LOPO and HO parts?
                          Including AOD transmssions.
                          Anyone?
                            Explorer intake is NOT 65mm, this was very misleading. It is in fact 70mm and I can provide picture proof if needed.
                            1991 Grand Marquis LS blog- Mayhem; two 12" Kenwood 800w subs, True dual catback, BBK shorties, cherrybombs, steel top, L/H hella lights, 18" AR Torq thrust, Trans cooler, class 3 hitch kit, more on the way...
                              zat so? now post up a pic, and beeter have a digital caliper on that sucker, cuase ill be posting mine here shortly you are talking about the TB right?
                                Anyone?
                                roller 302: a 302 is a 302 is a 302........ only difference per say is cam, heads e7 truck heads , pistons till 92 they were forged in the HO thats it bottom end is the same lopo or HO
