Someone else probably has a better picture than this, but here's one of mine that was worn out when I removed it.
Trac-loc rebuild ?
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by 1980c10 View PostThanks guys now I know what too look for haha.
Originally posted by Pirate View PostYou might also be aware of another problem that might pop up (or out) when you remove the rear-end cover; adult badgers like to crawl into the rear-end housing via' the vent on top of the rear-end....and then they wrap themselves around the ring gear. It's not uncommon to find 7 or 8 dead badgers inside of the rear-end housing when you pop the cover off.
'90 LX 5.0 mustang
Big plans
My drivers side axle was pretty trashed.
You shouldn't clearly see where the rollers were sitting, unless you pulled that axle after the car had been sitting for years. Kind of wierd to see that pattern, I'd expect a more uniform wear ring since the bearings roll across that area. What do the bearings themselves look like? If the axle looks like that, I'm sure they're toast but it might be interesting to see if the rollers are still round, or if they're flat spotted.86 Lincoln Town Car (Galactica).
Can you take pics!?~David~
Originally posted by gadget73 View PostYou shouldn't clearly see where the rollers were sitting, unless you pulled that axle after the car had been sitting for years. Kind of wierd to see that pattern, I'd expect a more uniform wear ring since the bearings roll across that area. What do the bearings themselves look like? If the axle looks like that, I'm sure they're toast but it might be interesting to see if the rollers are still round, or if they're flat spotted.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
maybe the bearings were screwed and then replaced, but they didn't replace the axle shafts?
I took a few pics of my rebuild when scott rebuild mine this past weekend I got to post them my original axles were trashed the right side was groved in pretty bad. the left side was pitted bad. my master rebuild kit was 76 bucks on ebay. and my clutchs for the trac lock was 82 shipped on ebay. they are carbon fiber cluthes
