how do i do that? im sorry but can u explain it step by step so i can fully understand it
Removing balancer
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Not a problem. Just set up your socket and breaker bar like I described before, and then use the starter motor to turn the engine. The starter should have enough strength to both turn the engine and break that bolt loose, especially since the spark plugs are out and it won't have to fight the engine's compression anymore.
just make absolutely sure you have it in proper direction to loosen the bolt.. the engine is gonna spin one way and the bar will be wedged on either the ground or a part of the frame/suspension.. when you bump the engine over it will loosen the crank bolt, all it takes is a little bump and it will be loose....
you definetely dont wanna be anywhere near the bar, definetely not holding it.. just be patient and if it falls off put it back on and start over..
take your time and think about it, be extremely careful or just use an air tool..
http://www.youtube.com/watch?v=S_-FsVvNr40Last edited by cld783; 11-03-2009, 07:21 PM.Give a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
sorry for asking so many questions ok let's get the straight to remove the large bolt I can position a breaker bar in the direction to remove the bolt. I can place it on the frame so I wouldn't get hurt so after putting it in place I guess that I give the engine a bumb which I think means to put the key in the ignition and give it a quick crank? Please correct me
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
You've got the idea, Mike. Did you watch the video?
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Cool! Be sure to let us know if we can be of any further assistance with the rest of your project.
Originally posted by Nathan in MI View Postcld makes a good suggestion, too. Disable the ignition system, put your socket and breaker bar on there, and then let it rest against the frame rail or whatever's handy that will keep the bar from turning. Then, bump the engine over with the starter a couple of times, and voila. You'll probably have to hold the bar in place by hand so it doesn't just fall off, so make absolutely sure that you're not going to get hands/arms/hair caught in any moving parts.
