Removing balancer
    how do i do that? im sorry but can u explain it step by step so i can fully understand it
      Not a problem. Just set up your socket and breaker bar like I described before, and then use the starter motor to turn the engine. The starter should have enough strength to both turn the engine and break that bolt loose, especially since the spark plugs are out and it won't have to fight the engine's compression anymore.
        just make absolutely sure you have it in proper direction to loosen the bolt.. the engine is gonna spin one way and the bar will be wedged on either the ground or a part of the frame/suspension.. when you bump the engine over it will loosen the crank bolt, all it takes is a little bump and it will be loose....
        you definetely dont wanna be anywhere near the bar, definetely not holding it.. just be patient and if it falls off put it back on and start over..
        take your time and think about it, be extremely careful or just use an air tool..
        http://www.youtube.com/watch?v=S_-FsVvNr40
          sorry for asking so many questions ok let's get the straight to remove the large bolt I can position a breaker bar in the direction to remove the bolt. I can place it on the frame so I wouldn't get hurt so after putting it in place I guess that I give the engine a bumb which I think means to put the key in the ignition and give it a quick crank? Please correct me
            Just hit the starter real quick and check the bolt to see if it's loose. Try again if it's still tight.
              You've got the idea, Mike. Did you watch the video?
                Yea I did watch it I'm goin to give it a try tonight
                  Yea I tried it after I got out if work. And it worked great!!! Thanks alot
                    Cool! Be sure to let us know if we can be of any further assistance with the rest of your project.
                      Ok after I removed the balancer I noticed three little parts on the floor that I have no idea what the belong to I'll post up a pic later
                        Originally posted by Nathan in MI View Post
                        cld makes a good suggestion, too. Disable the ignition system, put your socket and breaker bar on there, and then let it rest against the frame rail or whatever's handy that will keep the bar from turning. Then, bump the engine over with the starter a couple of times, and voila. You'll probably have to hold the bar in place by hand so it doesn't just fall off, so make absolutely sure that you're not going to get hands/arms/hair caught in any moving parts.
                        You can bump the starter by shorting out the connector with a red cap on it at the passenger wheel well.
                          Nathan, Is the Red CV in the photo bucket picture a Fire Chief's car ? It does not look like the factory red. Nice looking.
