93 5.0 HO into an 89
    Ok, i bought a 93 5.0l HO engine that was in a t-bird. 90,000 on the clock and ran great when it was pulled. The reciver car is going to be my 89 GM. What I need to know is what else should i be doing when i pull the motor. Any suggestions on vacuum, ECM, transmission and other information. Thought about just putting the the heads on up on my exsisting block but then decided that it would be a better idea to put the younger assembly in all together. The pan I know is a double compartment like the pan on my 89 and the motor mounts and all will be in the same points. I am concerned about my cruise since it is an 89 and my be integrated into the ECM. The newer mother is just that, no harness or ECM. also there is no water pump but I can just use the one i already have since it is new. Thanks for the help guys. I tried to look in the archive but did see anything that really had what i need.
    sigpic 1994 Lincoln TC executive
    Hey I see that you live in Albermale! I live down here in Denton. I actually go the Stanly County comunity College. Other guys on this site will help you about your questions. I'd just thoght I'd post that.
      You will have to switch all your engine accessories around to do that. Your pump is not the same, it spins in the other direction, so you needs the belts to spin it accordingly.
      Former panther owner
      1981 CV 351 4bbl
      1991 CV 302 EFI
        greetings from Albemarle!
          Thats good to know, ill be collecting all the data I can on this. not going to put the gm down till i get another ride to drive to school and work. going to start the project in the spring time.
            I imagine the HO in a mark VII is the same basic engine so this is why I posted that above.
            Oh and this was funny today.....
            My wife, who is basically the finacial manager of things (yeah, I know, but she's actually pretty good at it)......asked me:
            "why can't you use the water pump off the lincoln?" (her Dad's 90' LSC parts car)
            ....Well after I got done rolling my eyes....I explained to her about the fact that that car had 168k on it......
            Then again......at that mileage it must have been changed at least once......LOL
            Originally posted by lincolnmania
            the mk7 water pump also turns the wrong way.......good you didnt try it!
            1981 CV 351 4bbl
            1991 CV 302 EFI
              Where you go to school at? I'm always coming down hwy 52 about 8 o clock in the morning.
              PS: Sorry to Hijack
                I go to ITT Tech in Charlotte, but i work at the shell station on 24/27 right outside town. How far away is Denten? I just moved back here. I use to live here about 3 years ago but now I am back.
                  well ill just get the water, ps pump, and alt for a t-bird and that should sove it, you think?
                    You can take hwy 49 and get to Denton. I'm about 20 or 30mins from down town Albemale. I'm sure you've heard of the little club called Cripple Creek? I go there every now and then
                      Sounds familiar but I dont get out much.
                        dont forget, you might need the MAF sensor and wiring and the ECM since the t-bird is a MAF car and our boxes are speed density
                          ....and here we go, leaving Tech Gulch, and entering Chat Flats...
                            You don't want that wiring harness or ECM. 93 Tbird stuff is way different, and the ECM tune pretty much blows. The pinout is also very different, so unless you really want to do a lot of work to modify your wiring harness, its not worth it. MAF may be useful down the road but thats about it. Snag the plug for it if you'd like.
                            Front engine accessories are all different. If I'm not mistaken, you may also need to change the timing cover to the same one your stock engine uses. The upper intake also is mostly useless. Its far easier to use the upper from an 88-92 Mark VII or Mustang since that style is reversible. ECM should be a Mark VII computer if you want plug and play with cruise control. The upstroke to this, from what I'm told the 93 Tbird engine has the same cam the 93 Cobra has, meaning its got a little more low rpm torque. I don't know that this is absoloute gospel but its what I've been told. If not, its the standard HO cam that works fine anyway.
                              thanks much for that info, the more the better. its not a fly by night project for me and soon me gm will not be the daily driver so what ever i got to do to get it right is fine with me, thans again.
