I have decided to use 2V's guide to add the delayed accessories modification to my P71.
I have a question regarding the first wiring set up for the first two relayts pictured on this page.
What kind of diodes did you use?
Judging by that write-up, I will need three: one for the ignition switch accessory wire (BR?), one for the driver's door ajar switch(DB), and one for the passenger door ajar switch (Bk/O). Is this correct?
What else am I not getting or missing?
I may just end up using the second relay diagram, which appears to only need one diode.
I'll probably have more questions of just the urge to get confirmation before I begin.
Thank you in advance.
