Page 51 of 52 FirstFirst ... 4149505152 LastLast
Results 1,001 to 1,020 of 1027
Thread: 1990 country squire resto/lowrider in UK
  1. #1001
    PROUD DADDY OF JILLIAN PICKUP6772's Avatar
    Jun 2005
    MASTIC BEACH, NY
    730
    YAY!!!!!!!
    Sent from my SAMSUNG-SM-T337A using Tapatalk
  2. #1002
    Sep 2014
    Warren, MI
    5,406
    woohoo! Andy's back!
    and yeah... self-preserving oil leaking bastards these cars are. I love it.
    This. Oil all over is a great thing, means no rust. You can still see the Ecoat on the floor pans because of it. Once you're done I suggest to either keep it away from salt & moisture or oil the piss out of it again.
  3. #1003
    Apr 2015
    Southern Commiefornia
    2,084
    Glad to see you back at it. No worries about lack of progress. For some of us that's a pretty common theme. Just pop in now and then to let us know how you're doing. Cheers!
  4. #1004
    Its good to be bacK!
    Thanks to all the "old timers" who are going to revisit this thread!! I think its time to get this wagon rolling.........
    My business is going well, but its time to step back a bit and have more time for me and my stuff!!
    Rocker panels time and then the bodywork is complete enough to put the body back on the chassis. Then assemble and paint and we should be good to roll next summer.
    This is the only rusty part of the car that has not been sorted out.
    Panel marked out for cutting
    And out it comes
    here's a view from outside the garage
    Here's the inside of the rocker i've just cut out. Can just about see some rust that has eaten away to make it very thin in places.
    Tomorrow i will start to fabricate a new panel from 1.5 mm thick steel sheet (exact thickness that the original was). Its slightly curved so I will have to make a former to bend it around.
    Oh, did i say, it was good to be back?!! laugh
    Andy.
  5. #1005
    18,453
    Yay. For updates on this full resto!.
  6. #1006
    Nov 2012
    Shelby Township, MI
    2,742
    Quote Originally Posted by andyfanshawe View Post
    ...we should be good to roll next summer.
    Light at the end of the tunnel?!
    Can't wait to see this one done.
    Gone but not forgotten:
  7. #1007
    20,908
    Light... and it's not a train!
  8. #1008
    Here's a view of the chassis outside my home garage and the body tilted for rocker panel redesign.
    1.5mm thick steel sheet bought and cardboard templates cut for the rocker panels.
    This photo may make it clear how Im going to do this.
    Since the car will sit on its rocker panels, they need to be strong. So I am going to build the replacement panels on the outside of the drivers side (as you can probably tell from the photo above), then cut out the old rockers and first weld in reinforcement sections that sit inside the rocker sections and tie together the inner, outer and door kick panels.
    Ill see if I can get a quick sketch............
  9. #1009
    37,524
    Bit limited on height there. Is that thing touching floor and ceiling on opposite corners?
  10. #1010
    Interesting you should say that! When the car is tilted at right angles to the floor, there is about 2mm clearance at the top and bottom! Made for interesting calculations when I designed the tilter.
    Andy.
  11. #1011
    Glad you're back. Scrupulous work. Donald
  12. #1012
    I post a lot... GoodSamaritan's Avatar
    Lawrenceburg, Ky
    2,233
    I have been away a long time, glad to see the project is still progressing. Incredible work as always Andy.
    Axle codes
    Open/Lock/Ratio #
    G / H / 2.26
    B / C / 2.47
    8 / M / 2.73
    7 / - / 3.07
    Y / Z / 3.08
    4 / D / 3.42
    F / R / 3.45
    5 / E / 3.27
    6 / W / 3.73
    2 / K / 3.55
    A / - / 3.63
    J / - / 3.85
  13. #1013
    Apr 2015
    2,084
    Lookin' good buddy, glad to see you're back at it. Be awesome to see that beast on the wee U.K. roads, lol.
  14. #1014
    Nov 1982
    Wetumpka, AL
    20,416
    Looking great, professional as always!
    You're really making me want to pick up a welder.
  15. #1015
    Back onto this monster for the next few days.
    Be interesting how many of the original forum members are still around reading this from day one...all those years ago!!
    Anyway, bodyshell back on its rotisserie and drivers side outer rocker panel cut out
    Interesting sight inside. i thought all this was rust free, but........
    But it doesn't stretch too far luckily, and is not severe. So I will media blast it clear and epoxy paint inside before welding.
    This is the picture of the back of the outer rockers. Notice the rust that was towards the front of the vehicle.
    Another good view of my home made tilter!
    Internal reinforcing panels next and I will start to weld the new panels in.
    Hope I can remember where all the parts are to put this car back together!! Been a loooong build.
    Amazing what obstacles life throws in your way sometimes.
    Andy.
  16. #1016
    20,908
    welcome back!
  17. #1017
    Nov 2012
    Shelby Township, MI
    2,742
    Back at it, YES!
    I was just wondering about this build recently after a new member from the UK with a 1985 Colony Park posted in the Newbie and Guest Forum.
  18. #1018
    4,990
    Ahh rust. Where there is a little, there is lots more hiding! The inner rockers on my 88 have been literally gone since I got it. Hopefully there is enough metal there to blast clean.
    1988 Crown Vic Wagon - daily
  19. #1019
    in the house of the hanged,no one talks about the rope grandwagon's Avatar
    Sep 2010
    glen burnie ,md.
    365
    glad you are back Andy!!!!
    '88' MGM wagon (mine and my sons toy)
    "60" chrysler New Yorker (my project)
    "78" Chevy 1 Ton P/U (yard horse)
    "01" Ford Explorer (wifes DD)
    "93" Chevy Suburban (my DD)
  20. #1020
    Nov 2006
    Dirty Jersey Yo!
    7,735
    I'm still here. Still amazed at the level of detail and the diligence put into this project.
    And yes, totally agree with you on the obstacles part. Simple engine swap turned into a saga of sorts. Haven't even touched the body yet :-/
Tags for this Thread
