The stress cracking around the body mount point doesn't surprise me all that much. If the mounts deteriorate, the body will move around more, causing flexing and fatigue. Its also just a high load area. Its probably also just not that strong to begin with.
1990 country squire resto/lowrider in UK
Had a sneak peek at the frame today since it was sunny!
Finished welding in the repairs to the frame mount on the right and closed off the panel with my spot welder
The seat belt reinforcement panel here is rusty
Here it is removed. Too much rust underneath.
Cut out the rust and plate made up to fit with a joddled edge. The numbers are for my good lady wife to push the panel with a pry bar while I weld it from underneath! I tell her the number and she pushes there!
Over to the other side. Which I am expecting to be just as bad.
In fact it was far worse
Heres a view from the other side to show how far the rust has gone
More welding to do then!
Andy.
nice work. its nice to see people putting in the nesassary work for a show car
Lets try to get this corner finally welded up so I can paint the underside and get the frame back!
Heres the last cut on the black line shown above
First panel made and tacked in place. Very very pleased with the fit considering it is going to be butt welded
Trial fitting the front section. Yet another good fit! Bit of luck eh?!
Different view
I have designed these panels so I can have maximum use of my spot welder and get zero distortion and weld it FAST.
The frame bolt hole will also be reinforced by the addition of a 1.6mm panel welded on top-just as I did on the other side.
Quite surprised how well these home made panels fit. I must be getting good! How long to get these skills? Started bodywork when I was about 19, and I'm 49 now. Thats 30 years practice. WOW!
I absolutely love doing this type of bodywork!!!
Anybody want theirs doing next?
Andy.
Nice work!
I've toyed with the idea of removing the fold up rear seating area, then mounting an air tank, and an auxiliary fuel under there.
When do you get your frame back?Owner of the only known 5 speed box wagon with a lift kit.
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
Originally posted by andyfanshawe View PostDoes this annoy anybody else as much as me!!
Guess whats coming out next!!
Andy.
but I just build junk to drive around, no where near what you build
but I also live in the rust belt too
"In science it is either physics or stamp collecting." - Ernest Rutherford
- Oct 2009
- 2878
- Keene NH
- Send PM
Andy."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Frame has been back ages!!
Still wrapped up on back garden.
Best photo I have at the moment.
Andy.
nice work!
You do beautiful work Andy, i'm amazed at the welding skills. The wagon is going to be great when you're done. Thanks for the frequent updates too
Originally posted by FatNasty View PostYou do beautiful work Andy, i'm amazed at the welding skills. The wagon is going to be great when you're done. Thanks for the frequent updates too
Andy.
