Pesty's 2003 P71
    This will only end in tears!
    Ooooh, cupholders.
      Originally posted by Grand_Marquis_GT View Post
      Mine handles great. And the turning radius is good, I can pull an EXCELLENT U-turn in mine :evil:
      Looks good, mang!
      I wouldn't necessarily call it a U-turn as more less an evil 180 complete with thick black rubber left on the street.
      08 Lincoln Navigator L - 233k
      03 Mercury Marauder- 63k
        Oh yeah, sleek looking sled mang!!
          Ok so the shuddering came back. So I figured the gas was dirty enough to clog the filter again. It helped a little bit but it is still having a serious lack of power and wanting to die. Any guesses on where I should go from here?
          1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
            air filter? TPS? CPS? Spark plugs? Dirty MAF?
              Is the idle speed erratic?
                No its solid. It drives around fine and you wouldn't know there was an issue if you never went past 3/4 throttle. It tends to do it more after its all the way warmed up. And will also will do it when its in neutral.
                  pull the codes maybe. How many miles? Original plugs? Any water down in the plug wells? Boots torn on the coils?
                    Well pulled the codes and got a evac deal. Pulled the injectors out and try looked like they were full of alabama mud. So I think I might have to go though the whole fuel system and clean it out. This is going to suck.
                      When I turn the traction control off, yes
                      Originally posted by Pesty351 View Post
                      You two need to come down to friday fest is what we need to do. And anyone one else in the area.
                      Once the weather gets better out, hell yeah!
                      I think those injectors are the same as the old style injectors, and are 19#. They should be easy to come by!
                        All the part #'s I was pulling up was showing it as '00 and up but will older ones still work? New they want 90 bucks a pop. So having more years available would be easier to find in a junk yard.
                          Well dropped the tank and its pretty damn gooey. I think Im going to have to rip a whole fuel system out of a junk yard car. Yay just what I wanted to be doing.
                            Does anyone know how the vapor system and fill tube come out of the top off the tank? I don't wanna break anything yanking on it.
                              it looks like you are on to something, but on those motors the symptoms you describe are usually COP's crapping out
                                depends if the injector plugs are EV1 or EV6 style. No functional difference, but the plugs are not the same. Older style square plug is EV1, smaller rounded plug is EV6. Snag a set out of a junkyard car that got wrecked hard.
