replace brother with one who won't crank up someone else's stereo past the point where it distorts. Problem solved.
Looking to find a good quality 6.5 speaker can handle 125watts rms
Originally posted by 83countrysquire View PostSo what your saying is that my amp is fine, just that when my brother was using it he pushed the limits of the amp and screwed everything up. So is there anyway to avoid this if I hook it up to my new sub. I never realy crank the bass I just want to have a balance of all the mid highs and low in my car a quality system basically.
"In science it is either physics or stamp collecting." - Ernest Rutherford
- Oct 2009
- 2878
- Keene NH
- Send PM
also play with the treble and bass settings, different songs will distort systems at different volumes, to get all you can you have to adjust things constantly."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
turn down the gain controls on the amp to keep it from getting too loud. and/or beat your brother about the face and neck.86 Lincoln Town Car (Galactica).
so I gunna add the other amp, so I need your guys opinion on wiring the mtx amp says to run 4 gauge to it and I have 8 gauge running to my planet audio, should i just run another line of 4 gauge for the other amp or re run both and use 4 gauge or just run 4 gauge off off battery than split to 8 gauge? I think im gunna have to upgrade to my 3g alt too soon lol dont think old alt can take itsigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
What wattage level amps are we talking about here?
And yeah, if you're running multiple amps, the 130 alternator would be a very good idea. That stocker is barely enough for the car, add a bunch of stereo stuff and its just a matter of time before the smoke comes out. Be careful, those things catch fire.86 Lincoln Town Car (Galactica).
well I got a 3g in my backyard so I think the change will happen asap. As for wattage the planet audio running 8 gauge is 400watts rms 800max and than the mono block mtx is 150watts rms.
Also my pioneer 690ub headunit has a problem of keep muting its self.sigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
so we're talking 1350 watts, which is roughly 100 amps of current draw peak? Yeah, you need a lot more alternator. 4 gauge is good for 135 amps, 8 ga is only good for 73 amps, so I'd probably run a 4 to the battery, and split it up in the trunk. Its not gonna pull 100 amps steady, thats just peak demand for short bursts so 4 ga should be plenty.
amp ratings from http://www.powerstream.com/Wire_Size.htm86 Lincoln Town Car (Galactica).
sound is also governed by the deck in my opionion. i just put a used alpine in my g/f sonata. i have never had one before , but let me tell you it is the best soundign deck that i have ever heard. alpines have many options, as well as true power rating. i have a 50x4 clarion and it isnt nearly as loud and clean as the alpine. if you want to go with an amp for a sub i would go with a monoblock. i have an infinity right now pushing 1 12 and it thumps pretty well, one of these days ill get two speakers to see what the 600rms will do.
at anyrate you should try looking here for decent 6.5 speakers
http://www.sonicelectronix.com/item_...e+SPS-600.html
and you can find soem good stuff also here
http://www.parts-express.com/speakers.cfm89 townie, mild exhuast up grades, soon to have loud ass stereo....
well yeah. garbage in, garbage out. If the output from the head unit sucks, all the amp can do is make loud suck.86 Lincoln Town Car (Galactica).
I love my pioneer it sounds amazing but its doing that mute thing i was talking about and I m not sure how to get it to stop muting it self. Ok so 4 ga back and than distribution block now what about the size fuse I should use I have a 100amp fuse on the 8 gauge for the current amp so should I just stick with that fuse.sigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
Could try that. If it blows, a 125 or 150 ought to do it.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostDistortion is more likely you pushing the amplifier past it's limits than the speakers. When you overpower speakers, the voice coils get hot, and they either melt, or distort the pole piece to make the speaker rattle against the magnet or seize up. It doesn't cause distortion. The amplifier being run past it's limits makes for really nasty sound. I could get into the electrical reasons why, but it doesn't really matter, the short story is the amp can only run so loud before it changes music to horrible noise. That horribly distorted noise will blow a speaker out too, even if the speaker is rated to handle well above what the amplifier is rated to produce.
http://en.wikipedia.org/wiki/Clipping_(audio)
Keep in mind your amp gains ARE NOT a volume nob
What is your budget?
I run that same amp and these speakers CDT-CL61A my ears ring
Originally posted by johnunit View Postreplace brother with one who won't crank up someone else's stereo past the point where it distorts. Problem solved.
I remember I helped you pick that stuff out two years ago or so, too bad it isn't working out for ya.Last edited by saiyaneye; 07-18-2010, 06:16 AM.
yeah i know i love the speakers but the popping getting to me lol. I was trying just to get the 6.5 woofers cause I ll leave current component system in, i dont even use the tweeters for the back lol front ones are so loud. But I like the option of having them. But I wouldnt want to spend more than two hundered on a new set of speakers for the car.sigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
Make sure to match the gain on your amp to the RCA output level of your head unit - this is the #1 cause of things going to crap when you turn it up.
You will need to check yours, but most head units are 2 volts out, and most amp gain ranges are 0-4volts, so most gains need to be set at 50% and no more.
Some head units are 4 volts out, and amps differ, that's why you have to check and match them.
And like others said, you need to cut out the super low frequencies from the interior speakers altogether (using the amp's built in filter or a processor if the amp doesn't have one). Your speakers should come with a nice graph of their frequency response range, so you can cut them off from receiving anything past where the low end starts to drop off.
No need to try to make a little speaker do what the subs can more than handle.
When I first put my stereo together, i was using crappy radio shack amps and it didn't sound so great. Once I learned about gain matching and frequency filters, I bought an active signal splitter/filter and it made such a huge difference. Now i have some older Alpine amps with that stuff built in and it sounds even more butter.Last edited by 85crownHPP; 07-18-2010, 10:02 AM.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
