Page 1 of 4 123 ... LastLast
Results 1 to 20 of 70
Thread: Want to put a 460 in my lincoln, but i have some questions.
    n00b
    Dec 2008
    saylorsburg PA
    9
    Default Want to put a 460 in my lincoln, but i have some questions.
    I want to put in a 460 into my lincoln because they have so much torque and i love the 460. Anyway my question is will it fit in easily and can i use motor mounts from an F350 to make it fit? Also will my stock tranny bolt up to it? my tranny is whatever comes stock with the 5.0. Has anyone done this and if so can you let me know how easy or difficult it is and if its worth it. Thanks.
    1988 Lincoln Town Car
    -Cold Air Intake
    -True Dual Side Pipes
    The trash heap has spoken! Pesty351's Avatar
    Jul 2006
    Tyndall AFB, Fl
    2,577
    Keep dreaming.
    1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
    Pirate
    Guest
    Quote Originally Posted by crazyeights View Post
    Exhaust will be your main problem.
    Concerning motor mounts....I don't know. There's a guy with a completed 460 swap running aound, but there aren't a whole lot of details I remember. The main issue with a 460 swap is that you can get similar performance out of a modded 351W, unless someone has breathed on the 460 a bit.
    Mazda5: the Anti-Van! 1987cp's Avatar
    Dec 2006
    Michigan-ish
    5,811
    First of all, what are your power/performance goals? One of the things I've been figuring out recently is that most of what a person can make use of on the street can be done with a 302 or variants like a 347. A 351 can be stroked as 426ci and will bolt up using factory or factory-based parts.
    2012 Mazda5 Touring | Click below to buy my cool '81 LTD:
    n00b
    Dec 2008
    saylorsburg PA
    9
    well the thing is that my dad has an extra 460 motor. So i figured i could save money and gain that torque and horsepower with out spending a whole lot of money. i was just seeing if it was possible or easy to do and i guess not. I guess i could always do the HO swap. I want it to be a sleeper.
    -Cold Air Intake
    35,324
    nothing is going to be a drop-in. It can be done, but if you're looking for more performance on the cheap, its not going to be with a 460 in a panther. If its a stock late 70s 460 out of a Lincoln, they made like 250 hp, which you can easily make with an HO 302 and some tame bolt-ons. Not going to have that torque, but it will wind out a lot more than a wheezy low compression smog motor will.
    n00b
    Dec 2008
    saylorsburg PA
    9
    yea ill probably do the HO swap. I already have the HO components anyway i was just curious about the 460.
    -Cold Air Intake
    GMN Regular
    Mar 2008
    Fredericton, N.B. Canada
    12,405
    As the others have said, a HO swap will give you less headaches. Since you already have the HO parts, you can get started whenever you're ready
    '79 Continental Town Car *In storage for the winter.*
    '90 Crown Victoria LTD *In storage for the winter.*
    '92 Crown Victoria Touring Sedan *Parts car.*
    '94 Crown Victoria *Daily driver.*
    Prineville, Oregon
    21,802
    I guess I'll be the black sheep and say....do it. A lot of negativity in this thread.
    GMN Regular insomniac391's Avatar
    May 2009
    Baltimore, Maryland
    1,300
    is there even any after-market support for a 460?
    Oct 2008
    Buffalo, NY
    4,936
    Quote Originally Posted by insomniac391 View Post
    Tons.
    I know that one guy on cvn ran what, a mid 14 best with his 460 box. Then again, I think it was fairly stock.
    May 2009
    Baltimore, Maryland
    1,300
    Tons.
    hmmm, i never hear about 460's on the track, thats why i ask. I was looking at a Lincoln with a 460 for the longest time, but idk, i felt like it would just cost me $100 a week in gas for no reason.
    Dec 2006
    Michigan-ish
    5,811
    Quote Originally Posted by 79lincolnlover View Post
    Or perhaps more to the point, some of the dough that would go toward making the 460 fit (like getting a tranny with a big block bellhousing) could be better spent on things like good heads.
    BTW, 14s in a Panther with 7.5 liters? After all that hassle for such lousy results, I'd probably fake a broken hood release and claim it was a straight-six.
    35,324
    The 460 can be done, but its just not going to be easy or cheap. I wasn't trying to be negative, only cater to the indication that the original poster wanted something that wasn't terribly difficult to do. With enough time and money, anything is possible but its not going to be a couple hundred buck weekend project by any stretch.
    Pirate
    Guest
    Quote Originally Posted by Jonathan View Post
    Yeah, no shit.
    I'm not completely against it, I'd just pick a bit more friendly motor to start out with, or be prepared to mod the 460 truck motor before installing it, as power-to-weight suffers with this tank of an engine, when stock.
    I've got a couple of ideas for a 460-swap into a Box, but even though I probably won't ever get around to doing them, I don't want to quash this kid's enthusiasm.
    I'd be prepared to spend a bit of money, however, lol.
    Tons.
    Yes, that one was a bit disappointing.
    Jun 2009
    Nova Scotia, Canada
    8,260
    Anyone ever put other ford big blocks in a panther?
    Dec 2006
    Michigan-ish
    5,811
    What other big-block would you build? Is there any big-block other than the 385 series being built by anyone other than resto or nostalgia nuts?
    GMN Regular andymac0035's Avatar
    Jun 2009
    Grafton, NH
    1,259
    Probably not, but a 427 side-oiler (with a top-loader 4-speed) would be soooooo cool!
    Former panther owner
    1981 CV 351 4bbl
    1991 CV 302 EFI
    Member 351m's Avatar
    Dec 2008
    Prince George B.C.
    574
    Quote Originally Posted by 1987cp View Post
    LOTS, the aussies are all over the 400s it seems, they like the low end grunt over the 302c/351c... For the 460, it would be cool to see what he can do with it.
    Look at custom engine mounts, trans mount and probably a modded driveshaft though.
    1990 LTD Crown Vic w/ dead 5.0
    1984 Pontiac 6000 cammed 2.5L Iron Duke
    1986 F-150 300 6cyl 5spd.
    1994 Crown Vic... Free, bad trans?
    Jun 2009
    Nova Scotia, Canada
    8,260
    Was gonna say 429 CJ
Tags for this Thread
