Results 1 to 10 of 10
Thread: Water in my Muffler??
    Question Water in my Muffler??
    Hey whats up, I have a question and i am not sure where it need to go but here it goes. I have a 97 mgm 4.6 V8 and it has 225,000 miles and still going strong. but lately when the can is in park i noticed that the engine itself shake every now and then, also when i rev it up i have been told that the muffler spits out a little bit of water. is that normal? And when i am at a stop light and then press the gas my merc will shake a little as it picks up speed and the check light will then start to flash for a while and stay on. does anyone know what might be the problem i love my car me and her have been go hell and back. help me please!!!!!
    24,831
    probably needs a tune up. How old are the plugs, wires, and fuel filter?
    the moisture in the exhaust is normal with a cold engine.
    the flashing CEL is a misfire, probably time for a tuneup, most likely wires are the cause, dirty injectors are also suspect
    Okay thanks on the exhaust part. i think its time for a tune up too. what does a good super tune up consist of. also how can i tell if my injectors are bad or dirty.
    plugs, wires, fuel filter, pcv valve, air filter
    get some injector cleaner you pour in the tank, spend money on the good stuff
    sea foam is good stuff also
    does anybody know how much does the Ford house charge to put your car on their scan machine? Oh thanks for the input will be part and see what happens.
    Jan 2007
    Westmont, New Jersey
    9,179
    Quote Originally Posted by jayh View Post
    Catalytic Converter damaging if it flashes on and off.
    Vicky
    Currently Undergoing A Skippyville Beauty Makeover! Too Much Stuff To List
    Blue
    Mods So Far:
    5.0 HO Swap from 92 Cougar (Courtesy of Lincolnmania, Gadget73 and SVT98t), Electric Cooling Fan, Autodimming Mirror With Compass, Frankensteined but fully functional JBL Premium Sound System, HPP wheels, Working A/C, more mods to come soon!
    a flashing CEL is a current misfire, yes this can damage the cat, but thats not what is causing it to flash
    GrandMerc97 if I was a betting man, I would say your plug wires are the root cause; dirty injectors are also a possibilty, but the wires being old is alot more probable
    P71 junkie 87DeuceVic's Avatar
    Jun 2007
    Keene, NH
    1,879
    Quote Originally Posted by GrandMerc97 View Post
    I took my 94 Vic to the Ford dealer for a CEL and it was around $50 for the diagnoses.
    -2006 Dodge Ram Night Runner - "Shadow" - Toy/Driver #2 - Promoted to toy status, HEMI, tinted taillights, 4x4, reg cab/short bed, 1 of 2000 Night Runner's
    -2004 Crown Victoria Police Interceptor - Daily Driver - Ex-New Hampshire State Police, Unity spotlight
    -1987 Crown Victoria 2-Door - Project Car - 90k miles, Summit chambered muffler, Sunpro gauges, parked for 2 years awaiting resto
    okay here is an update so far I call the ford Dealership in my area and they said it would be $90 to check to car. WOW thats alot but i will replace the wires and reset the computer and post an update but will just get autozone to check the CEL and post their results Thanks
