Page 27 of 27 FirstFirst ... 17252627
Results 521 to 536 of 536
Thread: Sly's Panthers
  1. #521
    Mar 2010
    Lewisville, TX
    20,468
    Figured I should post the pics of the coolant filter here too.
ID:	49047 Click image for larger version.
  2. #522
    Mar 2010
    Lewisville, TX
    20,468
    First filter change already. I knew it wouldn't take long. Lots of gravel...
ID:	49045 Click image for larger version.
  3. #523
    Mar 2006
    Bedford, VA
    4,803
    Attachment 49043 Attachment 49044
    “Invalid Attachment specified. If you followed a valid link, please notify the administrator”
    1988 Crown Vic Wagon - daily
  4. #524
    Mar 2010
    Lewisville, TX
    20,468
    Fixed... apparently the forum changed the attachment number. Had to "Go Advanced" and use the attach function to find them. Also fixed the previous post that had the same issue.
  5. #525
    Mar 2010
    Lewisville, TX
    20,468
    Apparently there was still some damage to the Cake from getting rear-ended that I didn't know about. The driver seat rails broke today. So I got my spare set out of storage and got to work swapping them.
    Then I discovered that the other side was attached by a prayer...
    Crap. So I went to my washer stash and found a washer that fit the massive nut that broke free of its welds and got to work welding that together to help reinforce the attachment and welded it to the chair after welding the torn pieces back together. If I didn't overcook the welds, it should hold fine. The other side is still good so it should still be safe to drive.
    Got the other rails attached and bolted it all down. All betterer.
ID:	49321 Click image for larger version.
  6. #526
    36,866
    The seat rails on these things are pretty flimsy when you get right to it, especially for the sort of abuse they take. Even without an accident, years of back and forth stress from accel/decel will weaken it.
  7. #527
    Mar 2010
    Lewisville, TX
    20,468
    Coolant filter mod on the Cake:
  8. #528
    Mar 2010
    Lewisville, TX
    20,468
    Thanks for the POTM folks
  9. #529
    Member Giraffe's Avatar
    Jan 2016
    Wichita Falls, TX
    729
    Of course I voted for the Cake.
    óJohn
    1990 Mercury Grand Marquis LS (POTM March 2017)
  10. #530
    Mar 2010
    Lewisville, TX
    20,468
    Cake is tuned... sorta. Still need to sort out the EVAP codes (P0453, P1451) as they are not equipped on my car (that stuff didn't come out until OBD-II). As stated in the what are you working on thread, I had to replace the IAC since the PCM expects the one I bought and not the one that was on there. It made a big difference. The coil resistance was the same, so that's not the issue, but it seems they changed something in the valve itself between 2002 and 2003. So the 03 IAC is on the shelf if anyone needs one. It works fine. Anyhoo... dyno video below. 266 ftlbs (couldn't lock in 3rd gear so this number is low as peak torque is below 3K rpm) and 234 hp. We did a baseline with the 01 PCM to start with and it showed 215 (216 at SF last year), so the numbers are comparable. HP is up almost 20 and I would wager torque is up a few if we could have locked in 3rd. I'll drive it around and see if it feels any peppier. I doubt I'll be able to feel 18hp.
  11. #531
    No mean-spiritedness here. IPreferDIY's Avatar
    Jul 2014
    Canada
    1,593
    Is the thing in the exhaust a sensor for the tune?
    mods: air filter box "tuba" (in place of the "trumpet"), headlight relay harness, J-mod (around 186,350 km), 70mm throttle body, NKL4 PCM (from a 2000 CVPI, nothing great there apart from highway cruising), KYB Gas-A-Just shocks (after >202,000 km on originals)
  12. #532
    36,866
    Wideband oxygen sensor I expect. Useful to know if its going way rich or lean.
    What was the reason for the ECM swap?
  13. #533
    Mar 2010
    Lewisville, TX
    20,468
    Transmission shifting. the 99 PCM just works much better than the 01 in that regard on an AODE. If I had a 4R7xW, it wouldn't be as much of an issue. The 99 also holds gears while the 01 neutrals out when you let off the gas. I prefer the holding of gears.
  14. #534
    36,866
    and that wasn't something that could be tuned in the 01?
  15. #535
    Mar 2010
    Lewisville, TX
    20,468
    Nope. At least not with SCT. Line pressure change can be done, shift points, but that's about it.
  16. #536
    Mar 2010
    Lewisville, TX
    20,468
    Swapped back to the 2001 PCM an got the car inspected a few weeks ago. Just going to leave it that way until the guy can get around to trying to binary edit the rom file. I may have him email me the rom file so I can try. Or maybe get a quarterhorse and try hacking it myself. In the meantime, I reduced the bass in the cake. Out go the twin 10s and in with a low profile single 10. Good enough for me and massive trunk available again.
    Big boom truck waster...
ID:	50905 Click image for larger version.
Name:	big box amp_.jpg
    New small boom and open trunk
Name:	small box open trunk_.jpg
ID:	50907 Click image for larger version.
Name:	small box and amp_.jpg
    I used the stock touring sedan subwoofer bracket and drilled some bolts through the box (Pioneer TS-SWX2502) and mounted it with that and some THICK plumbers tape to the board holding the amp and then the underside of the speaker box to give it some support up front. I may make a better bracket later, but this works for now.
Tags for this Thread
