I'm suprised they tuned it with dud sensors...
Sly's Panthers
they did a decent job considering. He said he would finish the tune for free once I got the OSS and other sensor BS sorted. Since I found the stock OSS on the trans... I'll just use that one for now and tap into the wiring where needed.
Apparently. I'm not crawling back under there to take a picture.
Rock auto has one though...
http://www.rockauto.com/catalog/moreinfo.php?pk=1354744
http://www.rockauto.com/catalog/x,ca...parttype,10634
yup... kinda up in the tunnel. gonna be a bit of a pisser to wire that up... but I can do it.
Herre:
03 Mercury Marauder- 63k
does the AODE have the 6 hole reluctor in that location?
I can check tonight at work. The pic is of the 4R70W I have. I don't have any AODE's lying around.
ok.
99 PCM is a no go. Definitely no likey the 03 motor. put the 01 PCM back in. Fired right up. Loaded the "tune" and it's acting funky. May put it to stock and see how that goes. The ECT is only reading 60, so I'll have to sort the wiring on that first. The oil pressure mod (like I did to the F150) works like a champ... and no adapters needed. Just jumper that 20 ohm resistor on the back of the cluster and put the sensor in place of the old one (plenty of room, but be quick about it... oil spills like a boss). Tomorrow will be wiring tracing. bah.
check the sensor itself first. its possible that its a dud. I dont remember what that came from.86 Lincoln Town Car (Galactica).
the sensor that was in it was a dud. already been replaced. Found the issue. Pin 33 on the PCM is not grounded (this should be grounded). I'll ground that wire tomorrow and that should sort it.
ground wired. Gonna drive it today and see how it does.
