KYB: gr2 vs gas-a-just?
    Forget what I said, for some reason (I'm thinking autocomplete or something) it filled in the quantity fields as 2 when I put the coils in my cart AFTER I put 2x for front and rear shocks
    415 shipped. That's better.
      ahhhh i was gunna say! lol, yeah that is much better.
      -Phil
        Do you need to do shocks and springs at the same time? I would like to, to make things more efficient, but if possible I may do shocks first and springs later. If it's easier to do it all at once that's the way I will try to go.
          It will be less time consuming to do them all at once, and a bit easier, but it can be done separately.
          1985 GMC 1500
            500 labor to change 4 shocks, 4 springs sounds about right.....front springs are a pita and the rear shocks are a pita......lotta time involved there
              Holy fuck, I had no idea it would be so expensive. Looks like if it happens, I'll be buying the parts and either doing it myself or having my mechanic (oil pan pump etc replacement: 225. he works cheap) do it.
              If I end up getting the coils from the member here that told me about getting rid of his, it'll be even cheaper still.
              They really take a long time, huh? Are we looking at a full day sort of thing?
                I have never done springs/shocks on any of these cars, but from doing my moms olds would say that it shouldn't take longer than a day. Of course I have been known to be wrong. I usually bank on a day for any of my projects so I don't feel rushed, although I gave myself the whole weekend on the PS pump and only really needed like 6 hours, and 2hrs was hunting down and yanking another pulley (because I bent mine using the wrong puller) in a scrapyard.
                1985 GMC 1500
                  anyone know of a hydraulic spring compressor that will work on a box? Would save LOADS of time for me replacing the bushings (not to mention the strain on my body from having to hand crank the brake-over bar around with those manual clamps).
                    I'm watching this thread with interest, since I have to change the control arm bushings on my box I'm changing the front springs too...
                    The rears I've got down to less than 4 hours easily for the complete change. Rear of car on jack stands, jack under side of axle you're working on, sharp 12" metal blade on a reciprocating saw for the top bolt (have some spares handy)(watch the various lines on the drivers side), cut the sway bar link (if they're old/bad might as well change them, assuming you've got a rear sway bar), unbolt the bottom of the shock, it'll drop out, lower the jack on the side you're working on, jack up the other side of the axle a fair amount (to seesaw the side you're working on down), the factory spring should just be sitting in there kinda loose, yank or pry it out (always be careful with car springs, make sure they're not under tension - they can kill you if under tension!!!), sit the cargo coil in there (it'll be shorter so you'll have to lower the other side somewhat). Be sure the spring is seated properly before installing the shock.
                    Then ka-bam, tack the lower shock bolt in, tighten the top (you might have to jack up the axle a bit, a racheting combination wrench is great for tightening the top bolt, 7/16 iirc), just hold or even spin the top part of the shock itself to help tighten it. KYBs use a second nut on the top as a locker, install it, tighten the bottom bolt, wala'! On to the other side.
                    Don't forget to install stabilizer pins before taking the car down New sway bar bushings might be nice too.
                    I also spray all visible lines with oil while I'm under there.
                    Fronts, I await the experts too . Years ago, a buddy made up a spring compressor out of a bumper jack, the spring went through the side of his garage
                    Pete
                      kyb gas adjust & rear cop springs
                      Hey. For what it's worth , I just installed 4 gas adjust shocks (police) and new take out police rear springs in my 99 G Marquis on the weekend. I consider myself a fairly good backyard mechanic. It took me 8 hours, mainly because of the poor access to the top rear shock bolts. The rear shocks are a real bitch. Got my shocks at Jegs. Love the rake and feel of my new ride.
                      99 GRAND MARQUIS
                      98 F150 STX
                      69 MUSTANG MACH 1 428 SCJ
                        I don't see anyone mentioning my favorite shock Bilstein. Have them in the E150, Volvo 740 Turbo and it looks like none in the new GM since they are no longer listed. Bilsteins last forever and have the best rebound control available. www.allshocks.com lists up to 2002 GM. Bilsteins, set of ADDCO sway bars and now the E150 Conversion Van handles like a... well it out corners pickups.
                        2009 GM, 45,000 miles
                        ADDCO Sway Bars, METCO Control arms & Watts link, KYB CVPI shocks, 3.27 Track Lock, GT500 wheels, Eagle F1 Supercar tires, Walker dual exhaust, AFE Cold Air intake, ADTR ported upper manifold, Stillen Sport Rotors, Hawk HPS pads, Hypertech Programmer, 93 tune.
                          yeah... personally I don't like KYB (KYBreaks) cause I've known too many people that have had them flat break on them after not much time (usually a week to a month when they do just blow) but this was also the oil filled models. I've had better experience with monroe (though they are not that great either... just wear out quicker than I would like) and I'm currently using gabriel ultra on the vic (still stock on the MGM). The vic corners like a compact car now. Had the ultras on there for a year now and there is no change (and I would know since i don't drive that one much since it's my wife's daily driver). The only problem I have with Blisten is price. They know their worth and charge for it. I got the full set (all 4) for the vic for the price of ONE Blisten and have no complaints about the gabriel shocks.
                            I just got a quote from the same place that did my mufflers..KYB gas-a-just cop shocks all around, with Moog regular rate wagon springs in the rear and cop springs in the front, $1000 installed.
                            yeah canadian prices, I live close to michigan so I rip over the border for all my parts... samn near half price and 10 the selection we have over here.
                            anyone can do the rear shocks and springs with only a jack and wrenches (shit tonnes of patience and time are also needed). front shocks are no prob but the springs require a compressor and would be a good job to have someone else do...so might as well get them to do the front shocks while their at it.
                              Rear springs are a piece of cake. The fronts flat suck though. I don't know of any hydraulic compressors that will do the job. I'd really love to find the correct plate style compressor though. Those use the frame and a plate to compress the spring in place, rather than sitting inside the spring with hooks. It would make positioning things a ton easier since the spring would be where it belongs, and all you'd need to do is swing the control arm into place and put the nut on the ball joint. No fighting trying to get the spring in there at just the right angle so the screw doesn't jam against the frame, and then poking around at the parts to the compressor to get it back out of the spring once its all bolted up.
                                So the general consensus is:
                                rear springs: okay
                                rear shocks: okay
                                front shocks: okay
                                front springs: rotten bastards
                                Might do everything myself (or with assistance) besides the front springs if it's within the realm of possibility. Could get the shop to do the front springs.
