Results 1 to 17 of 17
Thread: CFI performance
    Minivans are tangible evidence of Evil.. 85MercPark's Avatar
    Jun 2005
    Harrisburg, PA
    3,295
    Default CFI performance
    So what can be done to CFI to increase HP? Besides replacing it!!
    2002 EGO electric scooter
    1997 F150 Ext Cab 8ft bed.
    Ex-Mercury Owners Group member
    24,848
    Changing the heads to a better design should help.
    Fack da Hulk Hogan! Grand Marquis GT's Avatar
    Nov 1982
    Hamilton, AL/Little Rock AFB, AR
    19,465
    convert to...
    No, just kidding
    Exhaust, a bump in timing...
    Quote Originally Posted by sniper308 View Post
    Everybody have some of crazy the difference is that some have a little less and some have a little more, I have a little less combined with some of eccentric. :heyhey:
    ATT, SNIPER 308. " YOU HAVE TO BE MY EYES " Tomb Raider.
    Quote Originally Posted by DuceAnAHalf View Post
    this.
    if your letting your girlfriend run your life like that, congratulations your a bitch. grab my pocket, i just bought you for two packs of cigarettes.
    Jun 2005
    Harrisburg, PA
    3,295
    Quote Originally Posted by Grand_Marquis_GT
    I have the timing set just below where it detonates already.
    As soon as this exhaust rots out I will go duals, maybe some salt water will help!!! :banana:
    I read KN is only good for high revs and can cause other problems anyways.
    Would better plugs and a stronger coil do any good?
    Jun 2005
    Harrisburg, PA
    3,295
    with the CFI computer would they really help?
    24,848
    You should be able to change the heads without changing the computer to get some extra performance. Its not going to be a rocket but better flow=more power. Also like Tom said, good dual exhaust with headers will help too. Changing the rear to something like a 3.55 or a 3.73 also would be a good idea.
    look at it...pelican fly!...come on PELICAN!!! marquisman's Avatar
    innisfil, ontario, canada
    8,977
    how bout a carb swa.......sorry, never mind
    1980 lincoln mark VI givenchy 2-door 351W- SOLD
    1981 mercury marquis brougham 2-door 302 special blend(GMGT)- summer toy
    1985 mercury grandmarquis LS colony park 351W- winter DD/back up
    1997 lincoln town car cartier 4.6L- current summer DD
    http://www.cardomain.com/id/marquisman
    central VA
    11,981
    yeah theres not much you can do besides better heads and exhaust without getting into a lot.
    You could possibly swap in a CFI mustang cam and computer too... tweak the fuel pressure regulator and even have to throttle bores machined larger... but CFI will never see real power do to its itty bitty internal fuel rail.
    Jun 2005
    Harrisburg, PA
    3,295
    Thanks, I will see what the bank account lets me do first.
    Tremont PA.
    15,275
    i would start with headers, h pipe, duals, and some gears.........3.55 is perfect for towing in drive
    Nov 1982
    19,465
    Nice avatar, ray!!
    this.
    Jun 2005
    Harrisburg, PA
    3,295
    Nice avatar, ray!!
    Thanks, I was gonna use
    But didn't wanna be too over the top
    Nov 1982
    19,465
    this.
    My Name is Fudge Flapjack.
    588
    I know of a guy who pulled the CFI body apart and removed the screens from the tops of the injectors and noticed that his car no longer had any off-idle hesitation. If you have the time to take the CFI body apart, it's worth a try.
    Jun 2005
    Harrisburg, PA
    3,295
    Quote Originally Posted by Ifixyawata
    I really don't notice any hesitation. I only have 34000 miles so that may be why.
    588
    Here's the guy's write-up on the process. He says you can also leave the screens all the way out, but if you want to be safe, add another in-line fuel filter, but you should be ok without it.
    fuel injector cleaning
    remove the cfi from intake
    split the cfi in half via three phillups bolts from the bottom.
    ,, removed the lower injector retainer (be careful on the screw or you will be taping a new hole).
    gently pull the injector out (keep track of your smaller orings).
    take a pointed tip screw start this screw into the brass bushing just at the top of the injector until it started to grab real good.
    grab the screw with pliers and pulled real hard and out pops the injector screen that is molded to the brass bushing.
    spray the injector screen assy down with starting fluid or something.
    Next, blast it with the air compressor.
    insert the screen assy back into the top of the injectors,, turn the injector upside down and tap it on the workbench which will seat the brass bushing part back in its seat.
    re-install the injectors and man does make a difference.
    the screen assy is only about a half inch long and about 3/16 in diameter. Pretty fragile looking also. I re-shaped the screen on one becase it was a bit sucked together. I re-shaped it with a small ink pen insert.
    Jun 2005
    Harrisburg, PA
    3,295
    don't sound like something I would want to try on my daily driver. Maybe if I get a spare cfi I can fool around with that
    Thanks
