It would be worth it to run an 8 gauge wire for those. Most amp wires are overkill, but an 8 would be healthy and would completely support those wattages.
Those watt ratings are most likely max watts. Root Mean Square (RMS) watts is how many you can actually put out, without distortion. Usually it's about 45% of the max watts. For example, I have a 600watt max 4 channel amp. thats 150watts per channel. Actual RMS per channel is 75watts. Most of the time the huge watt amps are worse. 1000watt mono amp putting 350watt RMS.
