Remove brake fluid until reservoir is half full. How?
    I want to inspect the caliper and piston of the front brakes.
    The instructions start with:
    "Remove brake fluid until reservoir is half full. "
    How do I do that?
    Thanks,
    Greetings,
    Arie
    BDRUP BDRUP BDRUP
    turkey baster?
      A spoon, suction pump, or as Duce mentioned, a turkey baster...
        ive used a straw before, brake fluid is not half bad, you might shit the bed though
          You could also bleed the brakes until the level goes down.
              bleed the brakes or use a turkey baster to suck fluid out of the master cyl
                you can use a clean lint free rag, like you would a paper towel.
                  I bought a syringe.
                  Works very good.
                  Thanks all,
                  Greetings,
                  Arie
                  BDRUP BDRUP BDRUP
                    ive dont that before too, the injector needles for turkeys are cool.
