Results 1 to 8 of 8
Thread: Rear end noob needs help
    The Green Bastard Leafsrule16's Avatar
    Jan 2010
    Canada
    319
    Default Rear end noob needs help
    Looking at a whole rear differential for $50. Its a 3.08 8.8 inch ford which im pretty sure is whats in my 97 grand marquis? I was told it would fit if i had a 31 spline axel it would be a perfect fit. Do i, and if not would it be easy to buy some for not a whole lot like maybe out of a junk yard and rig it up still with my air suspension/disc breaks?
    84 Chevy Silverado
    350 4 bolt main with a high rise edelbrock intake and 650 carb, ported heads, flat tops and a alright sized cam
    05 Honda Civic
    17 inch montegis and tint
    crazy about old Lincolns.
    Mar 2008
    Fredericton, N.B. Canada
    10,505
    If your GM's axle code is Y, then you have the 3:08 ratio.
    '79 Continental Town Car
    '83 Continental Mark VI
    '90 Crown Victoria LTD
    '92 Crown Victoria Touring Sedan *parts car.*
    Quote Originally Posted by Grand1 View Post
    The "higher ups" park next to me with their pods (ala Lexus, Acura) and think I'm gonna pimp slap 'em.
    24,860
    Its a 28 spline. There are many many variations of the Ford 8.8. You need to have one out of a panther chassis car from 83-97 or it wont fit. Ideally you want 92-97 so its an exact replacement.
    I was born a Rambler man, but with the death of AMC, I guess I'll take another Ford. pstrbrc's Avatar
    Dec 2009
    Elkhart, KS
    173
    Ford used 8.8's in anything rwd that could come with a V-8. Fox chassis, Exploders, pick-ups, you name it. The spline count only matters if you're swapping internals. It's the externals (suspension arm mounts, hub-to-hub dimension, stuff like that) that you need to get right. Easiest way to do that is to make sure it's out of a Panther chassis.
    '84 Grand Marquis
    Damn thing just keeps runnin'!
    "Half the harm that is done in this world is due to people who want to feel important." T.S. Elliot
    Jan 2010
    Canada
    319
    So i could do just an internal swap and i may only need to change the axels ect? I have a single rear end right now, so i could take the internals out possibly change axels and put in a posi ? Sorry, im sort of dumb when it come to this, know very little.
    84 Chevy Silverado
    05 Honda Civic
    Dec 2009
    Elkhart, KS
    173
    If you're serious, you need to find out what a transmission shop will charge for the work. This isn't really for a noob to do. You will need about $300 in specialty tool just for openers.
    '84 Grand Marquis
    24,860
    Yes, you can change the rear gears.
    yes, you can change the carrier to make it a traction lock
    Yes, you really ought to pay someone who knows how to do this work.
    Be aware that the outer axle bearings ought to be changed, and the outer seals must be changed when you do this. Its also very possible that the axles themselves need to be replaced. I'd probably also spring for new pinion bearing and seals since its going to be out. The inner bearings you can also change but they're likely OK.
    The sly one slymer's Avatar
    8,429
    I had to have the rear axle on my 88 rebuilt.. the only good bearing was the divers side wheel bearing. the passenger side was so bad it etched the axle (spacer bearing used) and the carriage bearings were about like gravel and the pinion bearing was shot to hell too. Wish I had the $$$ for the powertrax locker when I did that, but oh well... next time.
    rides: 88 MGM, 93 Vic, 82 Mark VI,
