Results 1 to 7 of 7
Thread: fuel-injector issue
    crazy about old Lincolns.
    Mar 2008
    Fredericton, N.B. Canada
    10,489
    Question fuel-injector issue
    Car: '92 CV
    Whenever the gas pedal is applied, I can hear a faint hissing sound. Any ideas?
    '79 Continental Town Car
    '83 Continental Mark VI
    '90 Crown Victoria LTD
    '92 Crown Victoria Touring Sedan *parts car.*
    Quote Originally Posted by 84GrandMarquis
    I saw the Sentra just as it got flat bedded away. The thing looked like it hit a brick wall.
    Jan 2007
    Westmont, New Jersey
    9,179
    Quote Originally Posted by 79lincolnlover View Post
    Car: '92 CV
    Couple questions to help narrow it down.
    What gives you the idea it's a fuel injector problem? Do you have a cold air intake on there? If yes they normally do have a hiss, especially when you give it gas. If no, and you have the stock crap, check the condition of the air intake system, the rubber hose going to the throttle body. Stuff in between the air filter and the throttle body (that might throw a check engine light since it would be finding air entering the engine that wasn't seen by the MAF sensor)
    Any change in the way the motor acts when you hear this noise compared to when you couldn't hear it?
    If you want to narrow down the noise, open the hood, take the throttle, which should be on the passenger side in the middle, and move it. You should be able to recreate the noise under the hood if it does it every time.
    Vicky
    Currently Undergoing A Skippyville Beauty Makeover! Too Much Stuff To List
    Blue
    Mods So Far:
    5.0 HO Swap from 92 Cougar (Courtesy of Lincolnmania, Gadget73 and SVT98t), Electric Cooling Fan, Autodimming Mirror With Compass, Frankensteined but fully functional JBL Premium Sound System, HPP wheels, Working A/C, more mods to come soon!
    Mar 2008
    10,489
    No check engine light. The engine never has any hesitation and there's always smooth power delivery.
    24,837
    Turn the radio up?
    Mar 2008
    10,489
    True...I can't hear it when there's music playing
    Fort Wayne IN
    5,307
    Check the parking brake release under the dash as it is known to come undone and produce a hiss along with the main vacuum fitting on the firewall.
    The sly one slymer's Avatar
    8,413
    as well as the parking brake release solenoid (vacuum actuator) actually popping it's bladder and hissing itself. Hence the one on my 88 MGM is not connected currently.
    rides: 88 MGM, 93 Vic, 82 Mark VI,
