Results 1 to 11 of 11
Thread: camshaft question
    Proud to be a GMN Member Brandon's Avatar
    Aug 2008
    North Carolina
    1,423
    Question camshaft question
    Hey guys. I was just wondering on how big of a cam can I run in the 351 without changing the torque converter? I am planning on running gt40 heads on it and would like to have a bigger cam. I wasn't sure of what would be a good cam with the stock torque converter.
    I want some grape drink baby, mmmm it's purple
    Oct 2008
    Cheshire, OH
    2,372
    Nothing lol. The stock H.O. cam isnt even good on a stock convertor in my opinion
    '90 LX 5.0 mustang
    Big plans
    The sly one slymer's Avatar
    8,424
    just be glad it's not an aero trans... the stock engine kills those converters. That was the first thing I had to fix on the 93 vic.
    rides: 88 MGM, 93 Vic, 82 Mark VI,
    I have heard a supercoupe converter is good?
    Pirate
    Guest
    Quote Originally Posted by 89crownlx View Post
    It's good for a couple of hundred more RPM....and that's about all.
    I'd recommend at least a 2400-2500 rpm stall unit.
    24,848
    The 351 converter stalls even lower than the standard 302 converter. Its truly horrible.
    Oct 2008
    Cheshire, OH
    2,372
    I read somewhere that the aode convertor stalls around 2400 is there any truth to that and could you get one out of a 94-95 5.0 stang and bolt it to a regular aod?
    '90 LX 5.0 mustang
    Big plans
    Aug 2008
    North Carolina
    1,423
    Yeah, I was thinking the same thing. But I think mustang trannys are a little different than ours. But i'm not sure about the torque converter.
    Oct 2008
    Cheshire, OH
    2,372
    The aod has some differences. The shift arm on the tranny is different and the mustang has a higher shift governor. Other than that identical, I have a mustang tranny in my marquis. I'm just not sure what the differences between the aod and aode are, I would assume the convertors are interchangeable as long as you get one from a 5.0 but .......
    We all know where assuming gets us.
    '90 LX 5.0 mustang
    Big plans
    Pirate
    Guest
    Quote Originally Posted by 1980c10 View Post
    If you're attempting to think about using an AODE convertor in an AOD....stop right there, lol. To keep this simple, it won't work.
    Oct 2008
    Cheshire, OH
    2,372
    easy enough lol. I wasnt thinking about it just aking suggestions for the op. I want a higher stall than that
    '90 LX 5.0 mustang
    Big plans
