Anyone know them? I'm fixing to try to build one. Also can you use 4r75w parts instead of 4r70W?
AOD WR clearance specs?
1989 Grand Marquis LS
flat black, 650 double pumper, random cam, hei, stealth intake, Police front springs, Wagon rear, Police rear bar, wagon front ,exploder wheels, 205/60-15 fronts 275/60-15 rears, 1 5/8" headers, 2.5" offroad x pipe, Eclipse front bucket seats, Custom floor shifter, 4.10 gears, aluminum driveshaft and daily driven. 16.77@83mphTags: None
Originally posted by Southern_Pride View PostAnyone know them? I'm fixing to try to build one. Also can you use 4r75w parts instead of 4r70W?
So far as the 4R75W parts go....I've not heard of them being compatible.
I don't mind buying the tools. I guess I should ask this on click click racing. I about every 10k miles on these used ones.1989 Grand Marquis LS
Originally posted by Blaze86Vic View PostThe end-play tool is simply a 1/2" X 1/2" solid metal bar. Any good strait edge that fits inside the bell-housing and spans the distance from one side to the other side on the flat pump mounting surface in the picture below will do.
