One thread, for all your 4.6L 2v needs.
1992-2010 4.6L (4601cc, 281ci)
Fluid Types
Automatic transmission fluid................... MERCON (95 and up use MERCON V)
Engine Oil........................................... 10W-30 (Warmer climates) 5W-30 (Colder climates)
Brake fluid.......................................... Heavy duty DOT 3
Power Steering fluid............................. MerconV
Coolant........................................... ... 50/50 mixture of glycol-based anti-freeze and water
Differential...................................... .. SAE 80W-90 GL-5 ( add 4 oz of friction modifier unless using full synthetic oil in Trac-lok equipped vehicles.)
Fluid Capacities
Engine oil........................................... 5 Quarts (DOHC & 2004+ SOHC 6 quarts)
Transmission (92-94 AODE)................... 12.3 Quarts
(95-present 4R70W,4R75W). 13.9 Quarts
Coolant 92-96..................................... 14.1 Quarts
97-10..................................... 15.8 Quarts
Differential...................................... ... 2.75 Quarts (Approx)
Ignition system
1992-1996.......................................... 0.054 in. gap
1997-2010.......................................... 0.054 in. gap
Firing order........................................ 1-3-7-2-6-5-4-8
1991-1993 Coil firing order
4 8
3 7
2 6
1 5
FRONT
Passenger Pack ------ Drivers Pack
1......3 ----------------- 7.......8
6......5 ----------------- 4.......2
1994-1997 Firing Order
4 8
3 7
2 6
1 5
FRONT
6......3 ----------------- 7.......2
1......5 ----------------- 4.......8
I am just starting. Please let me know what i'm missing.
