Results 1 to 7 of 7
Thread: Vinyl Top Removal
    Learning The Ways Of Box Panthers MattsLincoln's Avatar
    Jan 2010
    Shavertown, PA
    2,525
    Default Vinyl Top Removal
    i am getting my car repainted with the top off and a new vinyl top going on how do i remove the old top. This is on a 2-Door Mercury Grand Marquis.
    2004 Ford Crown Victoria LX HPP(Valerie)- Stock 241,000 miles body and trans, 90,000 miles on 07 Engine, 05-09 Mustang V6 Wheels
    35,663
    remove the trim around it, and start peeling. headliner needs to come out to access the nuts on the center belt trim. the rear stuff across the trunk area has little nuts inside the trunk. Side pieces I'm not sure about. Consult your shop manual, it has details for the trim installation. Not sure if those pop off or if they have slide-on rivets or what.
    Birdsboro PA.
    16,762
    once you get the vinyl off then the fun begins......you gotta get all the old glue off of the roof, this is done with some acetone or lacquer thinner and a scraper......it's messy and time consuming, the solvent will mess up the paint, so protect areas you dont want to get messed up with heavy plastic and tape
    I shall not pass this way again. Smokestacklightnin's Avatar
    Feb 2009
    Riverbottom, TX
    692
    The glue is the worst part of the job. I used all kinds of chemicals for strippers. Glue removers work good, acetone, and also brake fluid. If you dont mind messing up any paint it may come in contact with.
    1984 2Dr Crown Vic "The Millennium Falcon" RIP
    GMN = life johnunit's Avatar
    Apr 2009
    Toronto
    5,084
    also be prepared to spend a lot of time and/or money getting the bodywork under the vinyl smooth. There's probably a few dents you never knew about, and the seam on the C pillar will be pretty much totally unfinished.
    35,663
    bodywork isn't a big concern if the top is getting replaced though. In stock form, it is ugly under there.
    Monroe, NC
    2,432
    ^Yea, what they said.
    I had a royal PITA of a time getting the Fuzz/Glue off of my Merc's roof during the slicktop conversion. I got so sick of fucking with trying to dissolve and scrap all that nasty crap off, I just took a grinder and grinded all the shite off. Using a very light touch, so as not to remove any of the base metal, I got it done in 1 hour, and finally moved on.
    89 Lincoln Town Car Signature Ragtop - 5.0 HO swapped, many mods...
