ok my 87 gm is going to kiss a wall if I can't figure out what the hell is wrong with her.
I'll go to start, engine turns over and the starter continues to crank reguardless of running idle. Go to shut off, starter still tries to turn the engine over! The only way I can stop it is by disconnecting the battery.
So far, I have brand new battery cables, went through a starter or two, couple of solenoid relays (currently have a heavy duty relay installed). I went through that circuit with a fine tooth comb and found NO opens in wiring, anywhere.
I heard a rumor that it might be the ignition switch itself sticking in the first crank, which would make a little sense considering it hadn't done it a week or two after the new starter was installed. I was thinking with a new starter, just bumping the ignition cranks her over.
If anyone knows what is going on here help me out before I make a two ton molotov in my driveway!
