Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: Removing Smog Pump Stuff
    Learning The Ways Of Box Panthers MattsLincoln's Avatar
    Jan 2010
    Shavertown, PA
    2,525
    Default Removing Smog Pump Stuff
    hey guys i want to remove my smog pump and all it's unnecessary bullshit. Can you guys tell me how to get rid of it.
    2004 Ford Crown Victoria LX HPP(Valerie)- Stock 241,000 miles body and trans, 90,000 miles on 07 Engine, 05-09 Mustang V6 Wheels
    Mazda5: the Anti-Van! 1987cp's Avatar
    Dec 2006
    Michigan-ish
    5,811
    Do it, that's all you really need to know. Unless you have smog nazis being particularly silly about it.
    Well, that, and that the holes in the back of the heads can be plugged with 5/8-11 bolts. I use a piece of radiator hose with a closed-end lugnut and a couple of screw clamps to cap off the air-injection nipples on my aftermarket crossover pipes.
    And most guys use a 56" alternator belt once the pump is removed.
    Yeah, I think that's about it.
    Until a lot of years down the road when you get a F150 smog pump to build a crankcase evac system.
    2012 Mazda5 Touring | Click below to buy my cool '81 LTD:
    Jan 2010
    Shavertown, PA
    2,525
    there is this air pump thing that all these hoses connect to. Mostly they connect to the smog pump can that all be removed and plug up the vacuum line to it.
    Dec 2006
    Michigan-ish
    5,811
    Oh, was that your question?
    Yes, remove all of it, remove the tubes on the back of the heads and the tube going down to the exhaust, and plug it all up.
    Oct 2008
    Buffalo, NY
    4,936
    If it looks useless, remove it.
    I shall not pass this way again. Smokestacklightnin's Avatar
    Feb 2009
    Riverbottom, TX
    692
    Should have two belts, if your ac doesnt work just remove the belt to it. Remove the rubber hoses and mounting bracket. You can leave the the metal lines from the back of the heads and down to the cats. Should be check valves were the rubber hoses connect.
    1984 2Dr Crown Vic "The Millennium Falcon" RIP
    RESTORE ... MAINTAIN ... CUSTOMIZE rick99601's Avatar
    Oct 2005
    Westland, MI
    1,947
    would the S/P over heat if you just ran the 56" belt for the ac and left everything else the way it is?
    1994 MGM GS Montigua
    2002 Mustang GT Coupe
    Dec 2006
    Michigan-ish
    5,811
    "S/P" = smog pump? How would that overheat? Can't imagine any harm coming of it, but it seems pointless to leave the pump installed if you're not going to use it. Same with the injection plumbing on the back of the heads - get those off of there too. Very silly IMO to remove only part of a system that, for you anyway, is useless.
    Jan 2007
    Westmont, New Jersey
    10,110
    Why didn't you just keep it off when you pulled the engine? Lol. You didn't need that to run the engine. Or to keep the AC hooked up.
    Vicky
    Blue
    Mods So Far:
    5.0 HO Swap from 92 Cougar, GT40 Intakes With Remanufactured GT40P Heads, Contour Cooling Fans, Autodimming Mirror With Compass, Frankensteined but fully functional JBL Premium Sound System, Working A/C, Big Front Brake Swap, more mods to come soon!
    Dec 2006
    Michigan-ish
    5,811
    I seem to recall people suggesting that he shouldn't reinstall it, but he insisted that he wanted to. Seems I asked why twice, but never got an answer. Oh, well.
    Jan 2010
    Shavertown, PA
    2,525
    i don't know if i can take it off here because emissions testing may want that to be on or fail inspections.
    35,318
    it wont fail emissions, but it will likely fail the visual anti-tampering test if they actually look close. Find someone who isn't a stickler to do your inspections.
    Dec 2006
    Michigan-ish
    5,811
    Best to find that out first, then! It'd be really annoying to get everything off of there only to find out some smog Nazi won't let you register the car unless you put it all back on. One does hear stories about people/locations where they don't care how it sniffs if they say something isn't there that should be.
    Personal suggestion: write to local legislators and ask them to eliminate some of your hassles!
    "The finder of unobtainium and other magical items" zoomie's Avatar
    Jan 2009
    chestertown ny
    3,043
    too bad your not in my neck of the woods i have a buddy who does inspections in PA and wouldnt bother looking at the smog stuff
    351W & F.A.S.T equipped
    Aug 2010
    Aiken, SC
    364
    PA isn't officially a "smog-state". It depends on where you live...that's why they use two inspection stickers...one is for safety, the other for emissions, if you live in an area of the state that actually performs emissions testing. Sounds to me like you DO live in a smog test area, check up on local visual inspection laws before gutting the smog pump...or find a real easy going inspector. When I lived in Jersey, they spent the past 10-15yrs cracking down on shops just selling stickers without actually inspecting cars...cracking down hard...a 2-yr sticker cost me $150 just before I left, went up to $250 since they changed the stickers for 2010. It should be significantly easier and cheaper in PA to find a shop that can help you out.
    good luck,
    Don
    Oct 2005
    Westland, MI
    1,947
    thats why im hesitant to rip it all out. if the car was registered in michigan it would be no problem but illinois has their out testing facilities and they look under the hood.
    just to confirm- running a smaller belt to bypass the smog pump will not take any load off the engine?
    19,583
    it will take a small load off the engine. The smog pump does run all the time, but doesn't actually get used all the time (IIRC -just like the power steering pump). It doesn't load down the engine much though so you probably won't notice much improvement in power if any.
    Oct 2005
    Westland, MI
    1,947
    Quote Originally Posted by slymer View Post
    gotcha. you should be getting that any day now, btw.
    19,583
    yeah... hoping the mail today has it.
    P71 junkie 87DeuceVic's Avatar
    Jun 2007
    Keene, NH
    1,894
    In most states if your car is a classic, which is usually 25 years old then it doesnt need to be inspected. In NH thats the way it is, so this summer is the last time my 87 should be inspected.
    -2004 Crown Victoria Police Interceptor - Daily Driver - 17" Bullitt's, 235/55/17 Goodyear Eagles, Ex-NH State Police, best 1/4 mile time; 15.3 @ 90 mph
    -1987 Crown Victoria 2-Door - Project - 90k miles, Summit chambered muffler, Sunpro gauges, parked since 2010, fate tbd
