Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: front cig liters dead... like so many other things
    Default front cig liters dead... like so many other things
    hello everyone im new and hoping to get some answers from you panther vets
    i have an 1984 towncar pics coming soon
    here are my issues for now
    1. Cig lighter in the ash tray sparked on me and now cell phone charger and lighter wont charge up!!! do i just need to change thhe fuse if so can anyone direct me to a fuse diagram
    2.already saw the long sticky thread aboutt windows not rolling up so ill check it awesome!!!!!
    3.front passenger door will not open from the outside!!! back passenger door had the top of the lock pin (what you can pull up or push down to lock the door) broke off last winter when it was - 40. that door wont open at all...
    4 power locks i can unlock all the doors except for the back right but it will not lock the (kinda annoying) it makes a noise but nothing happens
    These are the main issues i would like to clear up... i dont mind using the lighters in the back for gps and ipod/phone charger but the doors bug me i hate having to tell people to go around and get in and slide over!!!!
    hopefully someone can help my big blue lady out!!!!
    other than that ive had this car for4 years and love it to death. i wanna post some pics and video soon
    thanks a bunch
    Matt
    RESTORE ... MAINTAIN ... CUSTOMIZE rick99601's Avatar
    Oct 2005
    Westland, MI
    1,947
    welcome to the party.
    1994 MGM GS Montigua
    2002 Mustang GT Coupe
    "The finder of unobtainium and other magical items" zoomie's Avatar
    Jan 2009
    Eustis florida
    3,059
    Quote Originally Posted by vitals_fading View Post
    === probably just popped the fuse in the box under the dash, i did that on accident by dropping a penny in one one day. use a test light to check for fuses the fast way.
    2.already saw the long sticky thread aboutt windows not rolling up so ill check it awesome!!!!! usually window motors go poop
    3.front passenger door will not open from the outside!!! back passenger door had the top of the lock pin (what you can pull up or push down to lock the door) broke off last winter when it was - 40. that door wont open at all... might have to take the door off and check out the linkage connectors, might have one broken,also get in there and see if you locked the back door by moving the rod
    4 power locks i can unlock all the doors except for the back right but it will not lock the (kinda annoying) it makes a noise but nothing happens, hmmm ill leave this for gadget hes the resident electrical guru
    thanks a bunch
    Matt
    well that about sums it up off the toop of my head welcome to GMN and post pics! i love the taillights on the 80-84 lincs
    20,490
    Welcome mang.
    If the cigar lighter popped it likely toasted the fuse. The fuse panel is located underneath the steering column which means you need to remove that panel. According to my evtm the front cigar circuit is powered through position 16. Position 16 (while looking at the fuse panel) is on the top row all the way to the right. Should be a 20amp fuse.
    For your door problems you will have to remove the door panels...which will be a pain for the p.side rear door since it does not open. May have to remove the rear seat to give you access to the push pins that hold the panel on after you unscrew the armrest. (back seat comes out by pushing the front edge of the seat downward and towards the rear of the car).
    Your door lock actuator is dying.
    Jan 2007
    Westmont, New Jersey
    10,401
    Holy double post batmang!!!
    The front passengers door sounds like the plastic clip for the exterior door handle broke and it's not connected to the latch anymore.
    My rear door lock won't lock either. It's half dead and so is yours. You gotta pull your door panel with the door shut for the door with the broken lock thing. I'd suggest pulling the bottom of the seat out for easier access to the bolts and screws.
    20,490
    Good catch. Fixing it.
    40,988
    yeah, sounds like the rear lock motor is dead, or if the lock button is still jammed under the door panel, thats gonna be why it won't unlock. Most likely you're gonna have to remove the door panel to at least fish the lock rod out, but likely replace the lock motor as well.
    Thanks for all the replies pics coming up now ill post a link check my youtube page as well
    Thanks for you comprehensive answers very helpful
    Matt
    Check It Out!!!
    Lincoln Towncar 1984
    www.youtube.com/loudtowncar
    20,490
    Referring to your video....
    I think you need to invest in a 130amp alternator...that along with the big three would help tremendously. Cant really do the big 3 with a 2g alternator...assuming that is what your car has.
    I have a new alternator!!! but not sure the model got it when i took possesion of the car the engine is really oiled up where is the best place to ground it all??? anyone take pics or a video... i know that would really get my power flowing. Sick of the lights going to the music lol unless im driving
    Check It Out!!!
    Jan 2007
    10,401
    3g alt can be found on later ford products. The original available for your car is a 2g which is prone to fires and weak amperage output. The 3g that will work for you is found in the '95 Mustang with a 5.0, 3.0 Liter Taurus from the mid '90s, and some others I can't think of off the top of my head.
    22,724
    95-98 windstars also have it (oddly enough)
    20,490
    Stock ground locations is fine...New stock alternator is just as bad as the alternator you replaced. they don't have a charge terminal but pitiful spade connectors which suck as described above by 86Vicky. Install an alternator from a 95 mustang GT run 4 gauge wire from the charge stud to the bat, or starter solenoid. and make up new thicker cables for the battery to starter solenoid and battery to engine block.
    For more info on the 3g conversion...(130 amps compared to 65 or so stock) just use the search function.
    40,988
    I think the Windstar alternator is the large frame model though.
    22,724
    nope... it's a small case. I've verified that through 3 different parts houses and a lot of ebay listings. also of added benefit is that the minivan offerings are generally cheaper for the same part than the mustang offerings. Usually by about $10.
    20,490
    How are they clocked though. Really makes no difference but I found it nice that the mustang one had everything in easy to reach locations.
    22,724
    that part I don't know... but three bolts out and rotate to your preferred clock so it's not really an issue.
    Hey guys gonna replace fuses today but my horn aint working either!!!!! What fuse position is the horn located??????
    Thanks for all the great help!
    Check It Out!!!
    central VA
    12,773
    What kind of amp do you have? It sounds like its maxed out or getting a bad voltage drop... what size power wire are you using? And why the hell is the sub in the back seat? lol
    Pioneer 600 watt rms 1200 max!!!! 4 gauge power wire. the sub is in the car because it is so cold i need to help it warm up plus sounds better!!!
    im getting a new car soon but i was asking about the fuses i need to know where the fuse is located for 1. the horn 2. front cigarette lighter thanks
    Check It Out!!!
Tags for this Thread
