So I am stuck driving my lincoln for a few weeks till I get my 79 merc on the road . This morning I came out to a dead batterie. So I boosted it to get to work, after I get there turn off the car and go to fire it back up and click click. So after boosting it again, I pull the negative cable off the batterie it still runs, So I tested the alternator and while running with the cables off its charging at about 14.5 volts. So I grabbed another batterie that tested good and put it in. That was fine for a while. Then tonight after about an hour of driving I came home, shut it down and now again the batterie is deader then a doornail. So Im kind of lost. If the alt is charging why has the car killed to batteries? could it have something to do with the volt regulator? oh I'll add that the first batt it killed was only about 6 months old.
'80 lincoln charging problem
If the regulator was bad I'd think it would read high or low volts while running. So the battery is drained immediately after driving and parking it? That's bizarre...Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Does the alternator get hot when the engine isn't running? I've seen shorted regulators or rectifiers cause that problem. Also, the trunk or glovebox lights aren't stuck on are they?86 Lincoln Town Car (Galactica).
check the hood light bracket too. That's the one I had to bend back to get my Mark from draining the battery.
mine didn't exactly act like that, mine the dash amp light bulb blew and i put on a new alternator new voltage reg. still nothing. read a thread on here about the dash light took my dash apart and the wiring sheet that runs the gauges on the back with the flat copper connetors had fallen apart so i ran a hot in run jumper to the light green striped wire on my voltage reg. and everythings been fine since.
What's the battery voltage at when you shut the car off? You got some kind of draw that's killing the battery. If the alternator is charging, then there's no way that the battery should be going dead that fast.
My bet is that under a load, like for example, the headlights are too much of a load on the alternator that has a weak output. Jump the car again, and run the car. Hook a volt meter up to it, and then put some loads on the system, wipers, lights, radio. If it can't supply the voltage necessary, you got a weak alternator.
ok that makes sence. It was fine thru the day. just tonight with the headlights and heater motor going is when it wouldent start, Same as this morning beacuse of driving last night with the lights and heater going. Also I notice with every time everything is running like lights heater etc sitting in drive with my foot on the break every thing dims and heater motor slows down, after speeding back up every thing brightens back up.. So im going to try an alternator.
1980 Lincoln Continental Mark VI Signature Series
351 4 bbl, AOD, 3.08 open
duel exhaust with cherry bombs
my Mark did that too with the stock alternator. I installed a 3g alt and it still does it a little, but not near as much.
the stock alternators on those are rather pathetic, 50 amps or something. The 130 works so much better its not even funny.86 Lincoln Town Car (Galactica).
yea i would do a 3ag conversion mang
Well I think its all fixed up now.. After changing the alt batt and voltage reg everthing seems to be working properly......so far. I always had alternator noise comming thru the speakers and that is now gone to. No more dimming sitting at ildle in drive. So Im pretty sure that the calpret was the voltage reg, baught that brand new for $40.
Before I did all that I hooked it up to the charging system tester at work, and with nothing on it was at 14.5 v and with everything on the volts kept droping way under what it should have been..
So anyways I think its fine now.. But thinking of a 3G swap not to long from now.
Originally posted by Grand_Marquis_LSS View PostSo after boosting it again, I pull the negative cable off the batterie it still runs, So I tested the alternator and while running with the cables off its charging at about 14.5 volts. .
Its especially a bad idea to do this with a computer controlled car. The unstable and dirty power coming out of an alternator can have unhappy results with the ECM and other electronics.
Sounds like you had a dead rectifier, which will cause weak and dirty output at a minimum, but can also create a sizable drain if it failed shorted. Usually the alternator gets quite warm if thats the case.86 Lincoln Town Car (Galactica).
