Originally posted by merc91
View Post
5.0 to 4.6 swap
The J-Mod, isn't that the thing where there's no accumulator springs or something? I was told from a bunch of the old Ford Technicians at my school, that direct clutch failures were either due to the tv bushing failure, or the hole in the direct clutch for fluid was too small, causing a lack of lubrication.
Originally posted by 86VickyLX View PostThe J-Mod, isn't that the thing where there's no accumulator springs or something? I was told from a bunch of the old Ford Technicians at my school, that direct clutch failures were either due to the tv bushing failure, or the hole in the direct clutch for fluid was too small, causing a lack of lubrication.
http://www.tccoa.com/articles/tranny...ybusiness.html1988 MGM GS - Preferred Equipment Package 172A; InstaClear
1994 MGM GS Montigua
2002 Mustang GT Coupe
its a 05 police interceptor that runs hard for a 4.6 and has headers, cold air, and a chip of some sort... i didn't buy the chip or tune the car, i just kno the guy. I will be sure to report my times when i go to the track. And yes my tranny slips so bad it shifts at 4000RPM but continues to rev up to 5000RPM while trying to grab. it's only got 50k on it and worked fine, just was meant for 150 hp, so the new built up one goes in in 1 month including a higher stall to go with it.
I just don't see why one would put a 4.6 into a box thats all... other than just doing it to have something different. Which is cool, i'm just throwing it out thier that more speed can be had for cheeper with a 5.0Finally have an on the books porting/custom fab business!
a f/i modular in a box would be sweet.
not so much n/a1988 MGM GS - Preferred Equipment Package 172A; InstaClear
Originally posted by merc91 View PostI just don't see why one would put a 4.6 into a box thats all... other than just doing it to have something different. Which is cool, i'm just throwing it out thier that more speed can be had for cheeper with a 5.0
a supercharged pi modular would be at 400hp on stock internals and a safe tune. thats fuckin awesome.
i love the pushrods and all, but ive got a soft spot for modulars.1988 MGM GS - Preferred Equipment Package 172A; InstaClear
I have made over 450HP on a cammed Explorer motor with N2O and I know of others who made over 500HP with a Paxton on a similar motor. NMRA Factory Stock Mustangs have dyno runs with over 350 FWHP using "unported" Explorer heads and Mustang "HO" cams.
im vowing to drop a 4.6 liter in a box within the next 5 years.1988 MGM GS - Preferred Equipment Package 172A; InstaClear
Originally posted by 86VickyLX View PostEh? That Continental have anything to do with it?sigpic
Originally posted by rick99601 View Postim vowing to drop a 4.6 liter in a box within the next 5 years.
