Results 1 to 19 of 19
Thread: a/c blower motor only works on high??!!!
    Dec 2010
    corona,ca
    161
    Default a/c blower motor only works on high??!!!
    My blower motor for the a/c/heater/vent only works on high.
    Thinking it was the switch I replaced the entire panel in the dash that has all the controls with one from a 2009 vic with only 35k miles...same deal...a/c only works on high.
    I'm reading it could be some sort of resistor or something?? Any ideas where to find this so called resistor? This is driving me crazy...nothing like having full blast only on a climate control system.
    -1999 P71 Crown vic X LAPD..
    -1966 mustang, 5.0 roller crate motor, t5 etc
    -1972 maverick 5.0 roller crate motor with EFI and a Lentech AOD
    Jun 2009
    Nova Scotia, Canada
    8,260
    blower motor resistor....it should be on the engine side of the firewall down around the evaporator housing heater core etc. on a 1991 or older i would say it's below the map sensor but i can't say for sure where it is on your car.
    Play me something funky! marquisman's Avatar
    innisfil, ontario, canada
    10,083
    chances are your blower speed resistor is fried. its located in the engine bay, on the firewall. pretty much by the pass side rocker cover. im sure someone here can post a pic.
    1980 Lincoln Mark VI Givenchy 2-Door 351W (PIMP hard)- SOLD
    1981 Mercury Marquis Brougham 2-Door 302 special blend (GMGT)- Summer fun
    1985 Mercury Grand Marquis LS Colony Park 351W (juice box)- Winter DD/back up
    1987 Lincoln Mark VII 302 (Errand runner) Summer fun
    1997 Lincoln Town Car Cartier 4.6L (Hustler)- Current summer DD
    17,471
    blower motor resistor...possibly located below the blower motor underneath the hood on the passengers side firewall.
    Just replaced one on a 95 explorer...and was still missing the third fan speed....turned out the harness was fired at the resistor. Had to rig something up....the contacts were not contacting the resistor killing the third fan speed.
    Could have a similar problem.
    Jun 2009
    Nova Scotia, Canada
    8,260
    19,338
    Here's pics of the screwed blower motor resister from my 88 (yours will have a different connector).
    Mine would only work on high at the time as well.
ID:	25727   Click image for larger version.
ID:	25728   Click image for larger version.
    Dec 2010
    corona,ca
    161
    wow, you guys rock...that's the single fastest response I've ever gotten to a question! This makes me extremely happy....now i've got my weekend project!
    34,966
    Is it automatic climate controls or manual? The auto cars don't use a resistor, they have a speed control module that lives in the same spot. The solder joints crack on them and cause the blower to not work. If thats what it is, you can take a soldering iron and flow a little fresh solder on the connections to make it work again most of the time. If its manual controls, then its most likely the resistor and/or the plug.
    Jun 2009
    Nova Scotia, Canada
    8,260
    probably not atc if it's a cop car
    34,966
    never know, I've seen some really weirdly optioned cop cars. Probably right tho.
    Jun 2009
    Nova Scotia, Canada
    8,260
    no you're right about the weirdly optioned cop cars.
    Dec 2010
    corona,ca
    161
    nah, this is a basic cop car...no cruise control, no special options...hell I'm happy that it has a/c and power windows.
    I found the connector and module on the firewall. the harness and plug "looks" ok from the outside...it's also got a broken tab on it where you pry up to pull the connector off. It's been off before...that either worries me that someones fixed it before and that wasn't the problem, or that it's just been fixed before and needs to be repaired again.
    Jun 2009
    Nova Scotia, Canada
    8,260
    You can try pulling it out and cleaning the contacts but it might not help at all.
    I registered just to say thanks for this!
    GMN Regular Toploader's Avatar
    May 2013
    1,396
    My '86 ATC has a resistor!....I replaced it and the blower motor on my quest to find out why high speed drops out then comes back on, I believe it is the vac can supply that is F-ed up, have not been able to find a new can as of yet.
    Member lincolnlarry's Avatar
    Nov 2010
    N.E. Ohio
    452
    New vacuum cans come quite cheap from the grocery store. I relocated mine to under the dash so I don't have to see it. Empty clean and paint!
    13 F-150 XLT 6.2 l
    19,338
    The ATC system has a controller hooked to the vent door position. If you lose vacuum the door position changes and drops the blower speed. The check valve on the firewall is usually to blame. Or the soup can has a hole in it.
    19,338
    And I use those plastic vacuum balls that run about a tenner.
    34,966
    Quote Originally Posted by Toploader View Post
    boxes have resistors. Round cars have a blower speed control module. I'd actually like to figure out a way to integrate one of those so I had fully variable fan speed vs 3, but I've been lazy.
    If you set it to auto, the fan speed will change as the car warms up. Its normal for it to go from high to medium as needed. If its not set to auto, then the vacuum supply has nothing to do with it. Auto only refers to fan speed, you can't make the temperature control non-automatic.
