Page 1 of 3 123 LastLast
Results 1 to 20 of 60
Thread: Quiet Performance Mufflers?
    Nov 2006
    Land of the Greasy Hair and Orange Biyatches
    6,161
    Question Quiet Performance Mufflers?
    My driver's side muffler is dying. It's a Summit welded Turbo Muff and the inlet pipe separated from the muffler casing. It's not terribly bad, just sounds like an exhaust leak for now. Hopefully I'll be able to get the muffler off of the exhaust without mangling the pipes. I'll probably replace it with the same muffler. However, if I can get the other muff off of the exhaust; I might just get better/more durable mufflers. The dual exhaust system is only 4 years old. So my question is: who makes a quiet performance muffler? I don't care if there's interior drone, just as long as it's quiet on the outside. I heard Dynamax makes decent flowing, but quiet mufflers. What say you?
    Dig deep in your mind; check what you find!
    "The finder of unobtainium and other magical items" zoomie's Avatar
    Jan 2009
    brushton NY
    2,976
    the hush thrush just came back out i heard nothing but good things abou them
    89 townie stock, repairs and upgrades on going..........
    I shall not pass this way again. Smokestacklightnin's Avatar
    Feb 2009
    Riverbottom, TX
    695
    I highly recommend magnaflow. They tend to be quiet until you really get into the throttle. Plus they have a lifetime warranty. I replaced the stock muffler on my 08 4.6 f150 crew cab with one, and is hardly noticeable till i get on it.
    1984 2Dr Crown Vic "The Millennium Falcon" RIP
    The sly one slymer's Avatar
    8,429
    Quote Originally Posted by Smokestacklightnin View Post
    I second this. My 93 vic and 88 MGM (stock engines) have duals with magnaflows (cats and mufflers) and the vic thumps some at idle (quietly) but will roar when you get in it... the mgm on the other hand will barely make much noise at all at idle and will not make a heck of a lot more noise when you hammer it with that lopo cam in it. It does sound nice IMO though.
    rides: 88 MGM, 93 Vic, 82 Mark VI,
    Nov 2006
    6,161
    Magnaflows are pricey, but if they last longer than four years, I will seriously consider them. If they're not quiet enough, I can always throw some glasspacks on the tailpipes.
    24,856
    I'm kinda surprised you only got 4 years out of those. My exhaust is about 5 years old and much of it is getting to that 'needs replacing' stage of life, but the mufflers haven't given me any trouble. They're the $15 each cheap of the cheap Summit turbos. I'd expect the welded ones to hold up better than the cheapo ones.
    Nov 2006
    6,161
    Apparently this one didn't hold up. It's possible that it received an impact or two during the four years. The exhaust does hang kinda low. I'm really thinking about getting under the CV this spring and taking measurements of the current shorty headers and H-pipe. I'll use those measurements to bend and weld a set of longtubes. Perhaps if I do that right, I can tuck the exhaust up a little under the chassis. For now, I'm going to replace the one muffler or go with Magnaflows. I'll probably just get another Summit muff for now. That'll have to wait until there's no more snow left in the driveway.
    Stow It! GM_Guy's Avatar
    Ontario, Canada
    1,331
    Magnaflows are a straight through muffler. Definately not quiet as far as I'm concerned, especially if you are looking for a muffler to be quiet.
    The Walker Super Turbo is about the quietest of the performance muffler segment, but does not come in a stainless steel version if thats a requirement.
    Yuuuuuupppppp... P72Ford's Avatar
    Feb 2007
    In the 860
    6,603
    In my opinion, if you want quiet exhaust, do not buy a muffler that is all steel construction. You have to have some sound abating material in order to combat drone, and excessive noise.
    I've never used Magnaflows (or quiet performance mufflers for that matter), but they have a great reputation. If you get some with a larger case, they will probably foot the bill perfectly.
    **1987 Ford CV Tudor, White, 302, AOD, 3.73s: Far from stock, stock from far
    **2004 Dodge Ram 1500 4x4 RCSB, Burgundy, 4.7, 5 spd: Daily driver
    **2012 Ford Mustang GT California Special, Race Red, 6 spd, 3.55s; Kook's, JLT, UPR: Street Heat
    central VA
    11,985
    Anything 'turbo' muffler is a safe bet for being on the quiet side.
    Lets put cough drops in out buttholes and play video games DuceAnAHalf's Avatar
    florida
    6,626
    Flowmaster delta 50's. The keep my long tubed cat less 351 quiet enough to not draw any attention
    NY
    13,283
    My magnaflows are pretty damn quite. Sounds nice when you rev up the engine though.
    Currently running mustang headers into mustang h pipe into s10 mids into magnaflows then turndowns. Not loud at all at idle.
    The bigger the Blob the better the job!
    Quote Originally Posted by Grand Marquis GT View Post
    You have to be the worst poster and/or the biggest fucking idiot on this planet.
    That's like swapping herpes for crabs.
    My 1987 Crown Victoria Coupe: The Brown Blob 0-60 in 8.43 sec, 1/4 in 16.75 sec @ 84mph
    My 1994 Escort: The Trusty Escort
    All Ford Family ford man's Avatar
    Jun 2008
    578
    I like my dynomax 'hemi' super turbos... the hemi means there 21" instead of 14". Sounds just like super turbos, just a little quieter. You still get a nice balance of engine noise and exhaust noise.
    24,856
    Do you have any fitment problems with the longer mufflers? I'm gonna need to replace mine, and I might be interested in the hemi superturbos if they fit up ok.
    Nov 2006
    6,161
    I was thinking about the Hemi Super Turbo muffs. Especially if they come in a longer case; it wouldn't be imperative to pull or very carefully cut the old muffs off.
    Jun 2008
    578
    My crown vic has stock exhaust. I have the hemi's on my '76 gran torino but the chassis is very similar and there was plenty of room... I also have hemi's on my '73 mustang and they fit in there, barely...
    There are some pictures of the hemi super turbos in my '76 gran torino readers ride thread...
    There is a video of the '73 mustang in the multimedia forum...
    Jun 2008
    578
    They would definitely make up some extra length mang! Hemi's are the longer 21" case.
    All you need is - glove? Piece-it pete's Avatar
    Mar 2009
    Cleveland. We rock.
    2,845
    I don't have much experience with mufflers for comparison. I like the magnaflows I currently have.
    Once in a blue moon the drone irritates me on the highway, but I like the way it sounds like a v8 even at idle.
    Occasionally they do catch a resonating frequency with the rear quarter, makes a buzzing noise I haven't found yet. But not a big deal.
    Pete
    1985 Lincoln Town Car Sig, "Faded Glory", For Sale: http://www.grandmarq.net/vb/showthre...highlight=1985
    bigger is better over2tonsofFun's Avatar
    Nov 2007
    Laramie, WY
    128
    I have the Jegs performance mufflers on the cat back system I put on my Town car. they are quiet. the cats are leaking so it a little noisy.
    Tim
    89 Lincoln town car: project drag week
    Save the US money, impeach him now
    Mazdas are sort of Ford-ish .... 1987cp's Avatar
    Dec 2006
    Michigan-ish
    5,668
    I thought you liked loud?
    I request you to get Walker Quietflows. Primarily because I want to hear what they actually sound like.
    IMO, performance mufflers = loud. Though Super Turbos aren't too awful. My short-lived Super Turbo system might have been pretty bearable if not for pipes trying to resonate me into oblivion.
    I also have a couple pairs of Flowbastards you could have for cheap.
    Black '81 two-door is FOR SALE! View thread, PM me an offer!
    Black '87 P72 is also FOR SALE! View thread, PM offer!
    New for-sale thread: http://www.grandmarq.net/vb/showthre...ht=#post670339
