I'm thinking, of swapping the trim panel from a '92 to the '94, since They're all the same, they're all black, so no worries that way.
Tripminders in Aeros?
in that case... party on!
Originally posted by slymer View Postin that case... party on!
Has anyone pulled apart these dashes around the clock? What is needed to disassemble it without breaking anything?
pull the middle trim off and remove half a dozen bolts and the 2 screws on the underside of the cluster hood. It's all one piece from the headlamp switch to the passenger vent IIRC.
think of a cap brim. the shade maker over the cluster... there's 2 screws up in there.
Aeros had digital dash available with the message center. Wouldn't it be easier (and more stock appearing) to swap one of those in? The speedos are already electronic in them anyway right? Obviously finding a dig dash equipped car in the yard to pull the harness from would help.
Past Panthers
Originally posted by tjc78 View PostAeros had digital dash available with the message center. Wouldn't it be easier (and more stock appearing) to swap one of those in? The speedos are already electronic in them anyway right? Obviously finding a dig dash equipped car in the yard to pull the harness from would help.
While it would be a cooler thing to do...
Have you ever seen the wiring behind one of those digital message center dashes? It's fucking insane.
Haven't had the pleasure... I am sure its worse than the boxes which aren't much fun either.
I know I was speaking to someone on here about converting a box TC to digital and they said it was a lot of work.2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
Originally posted by tjc78 View PostHaven't had the pleasure... I am sure its worse than the boxes which aren't much fun either.
I know I was speaking to someone on here about converting a box TC to digital and they said it was a lot of work.1988 MGM GS - Preferred Equipment Package 172A; InstaClear
1994 MGM GS Montigua
2002 Mustang GT Coupe
Alrighty, it looks like it is possible. The clock bezels are the same between the '92 and the '94 dash, possibly the '95 as well. The newest panther I have here to monkey with is the '94.
I just have to check to see if there is a fuel flow wire. If there is, the '94 is getting a tripminder!
if you find a working stock digital clock for a 93... lemme know. My 93 needs one.
