If I get the tripminder you can have the one out of the '94. Make an offer.
Tripminders in Aeros?
Originally posted by 86VickyLX View PostAlrighty, it looks like it is possible. The clock bezels are the same between the '92 and the '94 dash, possibly the '95 as well. The newest panther I have here to monkey with is the '94.
I just have to check to see if there is a fuel flow wire. If there is, the '94 is getting a tripminder!
lol1988 MGM GS - Preferred Equipment Package 172A; InstaClear
1994 MGM GS Montigua
2002 Mustang GT Coupe
Originally posted by game over View Postsorry for 1/2 off - is trip reminder wiring in box is the same as clock wiring or i need a new wiring and control module for trip reminder install?
If you don't have the fuel flow wire, of the cruise control wiring, you'll have to add it in. The fuel flow wire is a blue/purple wire, you'll need to get it from under the hood, if it's not a pigtail coming out of the engine harness, you will have to add the pin to the computer connector. Pin #34.
I'll ask this before I go on, do you have cruise control?
With a car that has a tripminder. Somebody on here may have the harness you need to plug one in.
You'll also need the tripminder unit as well of course. They frequently come up on here. So make a thread in the like to buy forum and you'll probably get some answers mang.
You'll need to make sure that the harness for the speed control also has the wire for fuel flow. As I said before, if not you'll have to run a wire to there.
ok, thank you. first of all i'll try to get it from very rusty crown victoria in russia. i know one car with tripminder here.
you say that speed sensor wiring is on the left of the steering wheel, but in which place on the dash it is located?'85 Colony Park LS
Look near the parking brake, up under the dash. You should see two connectors with black, green, and blue wires. That end of the wiring splices into the existing wiring for cars with factory cruise like a splice so you wind up unplugging two connectors on the end of the tripminder wiring.
Originally posted by rick99601 View Postduhh, i couldve told you that just by eyeballin it.
lol
Well, holy thread resurrection Batmang! Well I found a 92 specific dash panel. I installed my tripminder with the 92 specific bracketry. Spliced the wires in the cars harness. And now it is fully operational and looks like it belongs. I will have pics later. I need a tan interior piece, the gray one from the touring sedan is just poorly matched. I have yet to hook up the fuel flow wire but the odometer function works well. I gotta get motivated to disassemble the computer harness plug.
LOVE to see as many photos as possible! Mine FINALLY works ('87 GM) with much help from John. MANY THANKS!!
woot!
the original clock going to find it's way into my Vic? (at least the glove box so I can put it in later?)
