Page 1 of 4 123 ... LastLast
Results 1 to 20 of 71
Thread: update on 5 speed/306 swap! pics of trans!
    grand marq.net owns me Nick52284's Avatar
    Sep 2005
    Bethlehem Pa
    245
    Default update on 5 speed/306 swap! pics of trans!
    ok so its been a long time since i posted here, i'm still working on my merc that i got a few years ago, money was tight, life sucked for a while but i havent given up on this, i can't find my old post about the maroon grand marquis i got but its an 86 merc, 42,XXX miles, underneath is clean, since its been sitting the body developed 3 dime size spots of rust, nothing major.
    i finally got my engine down to the machine shop, getting bored to a 306, new freeze plugs, bearings, etc.. basically getting it ready to build,
    i got the trans setup today, everything is from the same mustang, just about everything i need to put the 5 speed in, minus a few things like brake master cylinder and driveshaft parts but here's the pics:
    already has a PRO 5.0 shifter installed, this thing is tight, feels really good
    the pedal assembly has an upgraded quadrant on it
    new clutch kit included with the trans
    new flywheel included as well
    also a new clutch cable was included, got everything for 500.00 total, not bad i'd say!
    Nick
    Sep 2005
    Bethlehem Pa
    245
    also i wanted to find out, will a stock pcm from a mustang work as plug and play in the grand marquis? since i'm swapping to a 5 speed i don't care about cruise, lol but i want the gauges to still work, as in speedo and odom. or do i need an ecm from a mk7 or thunderbird with a 5speed?
    I want some grape drink baby, mmmm it's purple
    Oct 2008
    Cheshire, OH
    2,371
    Are you converting to mass air or staying speed density?
    Btw I am jelous I would love to put a standard trans in mine.
    '90 LX 5.0 mustang
    Big plans
    "The finder of unobtainium and other magical items" zoomie's Avatar
    Jan 2009
    brushton NY
    2,976
    Quote Originally Posted by Nick52284 View Post
    ecm will work just fine, but the deciding factor will be if your running maf or sd on your choice of ecm
    89 townie stock, repairs and upgrades on going..........
    Sep 2005
    Bethlehem Pa
    245
    i want to go with MAF, which one will i need to run that?
    Oct 2008
    Cheshire, OH
    2,371
    a9l
    '90 LX 5.0 mustang
    Big plans
    Tremont PA.
    15,275
    very nice
    u can use a mustang maf ecm .......86 has standalone cruise control
    jack williams does shitty alignments!
    Sep 2005
    Bethlehem Pa
    245
    thanks guys!
    scott: i don't work there, they gave us a calendar because we buy a lot of tires from their warehouse.
    i'll have to scout an ecm then, i called the machine shop today, he didn't even touch my block yet, my fault for saying take your time... i figured he would have done something with it in 2 weeks, its the same place we use for our head jobs and other machine work and he's usually really good and fast. oh well, just gives me time to build up some more fundage again, lol
    Nick
    Sep 2005
    Bethlehem Pa
    245
    Apr 2009
    Toronto
    4,350
    nope. Where that says A6L on the label it shoulds say A9L
    85 4 door 351 CV - 160KMs stock and with issues... 4BBL swap and other goodies in the spring...next spring
    06 Mazda 3 hatch 2.3L 5AT (current daily)
    Sep 2005
    Bethlehem Pa
    245
    just got the call yesterday, my block is done! gonna pick it up this week, the guy hooked me up in a big way, for: hot tank cleaning, boring 30 over, new freeze plugs, new cam bearings and polishing the crank and cleaning the journals.... 200.00, i think i made out very well!
    pics of the block when i pick it up!
    Nick
    Sep 2005
    Bethlehem Pa
    245
    i got the block back a while ago but i have been pretty darn busy between work and starting a business for myself, here are the pics of the block, it is being sent back to the machine shop to have the bottom end and rotating assembly installed, once that is complete i'll post more pics!
    Feb 2011
    CO
    581
    Sounds like a lot of excuses to me. . .
    1992 CVLX. 5.0 HO/GT40P/T5/3.73/trak-lok with bolt ons. 02 front CVPI setup, rear HPP setup, CVPI shocks around, F250 radiator, e-fans, and the power of 3G. 15.92@89mph, 2.4 60', 4700' elevation (5500' DA) with 3.08 open rear and the old oil chugging 289.
    24,837
    cool. Get on with it already
    Sep 2005
    Bethlehem Pa
    245
    time and $$ holding me back, my job doesn't pay very well hence me trying to start my own business with my uncle - www.BrixPc.com
    Jan 2007
    Westmont, New Jersey
    9,179
    The killer of all projects...
    Vicky
    Currently Undergoing A Skippyville Beauty Makeover! Too Much Stuff To List
    Blue
    Mods So Far:
    5.0 HO Swap from 92 Cougar (Courtesy of Lincolnmania, Gadget73 and SVT98t), Electric Cooling Fan, Autodimming Mirror With Compass, Frankensteined but fully functional JBL Premium Sound System, HPP wheels, Working A/C, more mods to come soon!
    Feb 2011
    CO
    581
    2 lame excuses. He could sell a kidney to fund the project and put off starting the business until the swap is done. You need to get your priorities straight man.
    Sep 2005
    Bethlehem Pa
    245
    lol, yea, i'm taking baby steps, lol. at least once i get the engine back i can get an oil pump and oil pan, not too expensive, then i can mount the block and start working on getting the trans mounted and functioning. the project will speed up a little more i hope... also i decided to go with a carb setup for ease of install and that awesome 4 barrel feel and sound!
    Jan 2007
    9,179
    How does a car with a 4 barrel sound? If it's running right, it should be running as smooth as it would be with fuel injection...
    Vicky
    Blue
    Mods So Far:
    Sep 2005
    Bethlehem Pa
    245
    the sound of the secondaries opening up is unique to a mechanical 4 barrel setup from the video's i've seen and heard of 4 barrels anyway
