Well then your headunit's fucked. Get another one, or have it rebuilt
My JBL Swap(In Progress)
Originally posted by 86VickyLX View PostWell then your headunit's fucked. Get another one, or have it rebuilt
im getting it rebuilt after scottfest. problsbly will use yours until scottfest then. at least i can have music.
1982 Lincoln Continental Mark VI Bill Blass Designer Series 2-Door(Larisa)-Mods: HO Roller 302, GT40P Heads, Explorer Intakes, HO ECM(D9S), Autodimming w/compass and outside temp rearview mirror, Daniel Stern Lighting Mod, Dual Exhaust, 90's GM C/K Series Retractable Hood Light, Red Digital Dash Display, 92-94 White Leather Town Car Signature Cupholder Armrests, HPP Wheels, Police PS Cooler, Police Trans Cooler. More to come!!!!
The ground is in the power harness, plus I think it also grounds to some extend through it's mounting brackets. If one HU works and the other doesn't though, it pretty much nails it to a HU problem.86 Lincoln Town Car (Galactica).
just got a message from paul this is what it said.
So,
You say this problem happens regardless of whether you replace the amp OR the radio???
Sounds like you are pushing the amp(s) to its limits and its overcurrent/overheat protection circuitry is kicking in. Are the speakers the original factory speakers or aftermarket replacements? If they are aftermarket, they need to be 8 Ohm units. If they are 4 Ohm, they will cause the amp to trip out.
I have never seen a wiring issue (power or ground) cause the problem you describe.
Paul
well all my speakers are jbl speakers except for the dash speakers which are aftermarket pyle speakers. dont know what the ohms rating is got to check that may be the problem.
what size is the dash speakers so i know what to get. also my door speaker power and ground wires are powering my dash speakers too could that be the problem.Last edited by MattsLincoln; 07-10-2011, 02:08 AM.
another update. well i took out my dash speakers and yep they were 4 ohms so now i am running just ford jbl door speakers and rear deck speakers. and now no cutting out has happened i guess those 2 dash speakers were the problem. im happy now. now the hard part is finding 8 ohms speakers that will fit the dash speaker holes. if anyone has any they are selling or know links please send them to me.
Originally posted by MattsGrandMarquis View Postanother update. well i took out my dash speakers and yep they were 4 ohms so now i am running just ford jbl door speakers and rear deck speakers. and now no cutting out has happened i guess those 2 dash speakers were the problem. im happy now. now the hard part is finding 8 ohms speakers that will fit the dash speaker holes. if anyone has any they are selling or know links please send them to me.2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
5 inch 3 hole for factory... 4" with adapters (I have a set for $10 shipped - or I'll hand them to you at SF - the flat steel ones, not the thick plastic ones).
8ohm speakers can be found. You just have to search for component speakers... or get car speakers and wire a 4ohm power resistor (60-100W) in-line with one of the leads to the speakers.
The factory wiring puts the dash and door speakers in parallel, so you're OK there.86 Lincoln Town Car (Galactica).
well guess what the problem is still persisting. now its down to find out which of the 4 speakers left is putting out too much current. it has to be a speaker.
also slymer are those dash speakers 8 ohms.Last edited by MattsLincoln; 07-11-2011, 01:39 AM.
Originally posted by 86VickyLX View PostThat reminds me I should ohm out those speakers in my doors to make sure they'll behave with the jbl. They work with the stock premium sound, so I'd think it'd be ok with the JBL... who knows.
i wonder how many ohms the jbl speakers make. and hopefully a speaker is causing this problem cause if not then i am out of ideas except for rebuild of headunit and amp.
Originally posted by MattsGrandMarquis View Posti wonder how many ohms the jbl speakers make. and hopefully a speaker is causing this problem cause if not then i am out of ideas except for rebuild of headunit and amp.
However, you have to remember that the front speakers total resistance is less because they're wired in parallel.
Originally posted by 86VickyLX View PostYou have all of the speakers there... unless you threw out the dash speakers from the towncar
my speakers came from a mark vii only 4 speakers. that town cars dash speakers where shot.
