Still haven't found the source of my idle problem. You could say it's doing the whole "dies at stoplights" bit. New MAF, new IAC, new plugs and cleaned the carbon out of everything I could and I'm still dealing with this. No apparent vaccuum leaks. Tried checking for codes via EEC test and it wouldn't work. Tried different gauge wires and different grounding points and still nothing. Even tried the volt meter on the output end and I just got a constant power reading, no sweeps. Car won't even start the cycle to check the codes it just sits there. Car is a 1994 Grand Marquis LS. Video will explain the rest, thanks for watching.
http://www.youtube.com/watch?v=fP_FBOuw7qM
