Page 1 of 15 12311 ... LastLast
Results 1 to 20 of 281
Thread: My 1989 Lincoln 557 cobra jet project in progress
    Member lincolnlarry's Avatar
    Nov 2010
    N.E. Ohio
    452
    Talking My 1989 Lincoln 557 cobra jet project in progress
    I have a 1989 Lincoln Town Car that I have been playing with for about 3/4 year now. Started off wanting to put a 460 in this car I just bought. Well then it evolved from there. I decided to get a 557 stroker short block. I started porting a set of the good early oem heads Then decided to go with the Ford racing alum scj heads. They were a PIA since the intake and exhaust valves take diff length pushrods. Decided to use weiand cj intake. Comp cams deh265 since it has the same specs as the oem cj cam from 70-71. Hogged out some stock cj exhaust manifolds to match the scj exhaust ports then took out all the extra metal obstructions in all the runners. 2.5 dual exhaust with hooker aerochambers. JW ultrabell to mate to a very modified aod with lockup disabled. No lockup makes heat so on went the 35 gvr cooler. 327:1 with traction lock. And yes it is a 96 rear reflector I didn't like the 89 and original was in bad shape. Now, I just gotta get er done (little joke there) but I did feel like Tim Taylor every time i thought it just needs more power!!!!
    Attached Thumbnails Attached Thumbnails 047.jpg   6-8-11 008.jpg   5-31-2011 023.jpg   6-8-11 004.jpg   6-8-11 009.jpg
    GMN Regular
    Mar 2008
    Fredericton, N.B. Canada
    12,516
    Power shouldn't be an issue after this project hits the road/track! Going with a 9" rear?
    '79 Continental Town Car
    '90 Crown Victoria LTD
    '94 Crown Victoria
    GMN = life johnunit's Avatar
    Apr 2009
    Toronto
    5,085
    wow. very interesting.
    how far from on the road is this? Is it running a c6 tranny?
    "The finder of unobtainium and other magical items" zoomie's Avatar
    Jan 2009
    chestertown ny
    3,048
    i like!!!! and imn jealousof that steeringwheel!
    Wisconsin
    4,231
    Quote Originally Posted by johnunit View Post
    Quote Originally Posted by lincolnlarry View Post
    Wisconsin
    4,231
    What did you use for motor mounts? Which casting number exhaust manifolds? Mustang or Torino? Weiand Stealth CJ intake? Does the carb clear the hood?
    Jun 2009
    Nova Scotia, Canada
    8,260
    I love it. More pics and info!!!!!
    18,842
    The only problem you will have with this is stopping. Awesome build otherwise. Welcome!
    White collar, and a red neck P72Ford's Avatar
    Feb 2007
    In the 860
    7,165
    Nicely done.
    I can't see from the pictures... what are you using for a TV cable/ system?
    **1965 Ford Mustang Coupe: Currently on the Rotisserie, 306/T5/4.10s Long Term Street/ Strip Project
    **1990 Ford Mustang LX Hatchback: 5.0, 5 spd, 4.10s; 30K original miles Cruiser
    **2012 Ford Mustang Boss 302: 5.0, 6 spd, 3.73s; 17K miles Cruiser
    **2008 CVPI, Ex MSP Unit #420: 4.6, 3.55TL Flowmaster 10 knock offs, dark tint, JD Blitz Black, DD, CHALKBOARD
    **2012 Harley Davidson Wide Glide (FXDWG): 103, Cobra Speedsters, Cosmetics
    **2014 Ram 1500 QCSB Express 4WD Hemi/8spd TF/3L21 Truck Duties; Boesch Built, Cosmetics
    Nov 2010
    N.E. Ohio
    452
    Couple of more weeks and I should be on the road. Motor mounts are trans dapt truck mounts with the arms cut off and bushing re welded straight to the frame plate (from Summit). Manifolds are the mustang cjs they have the straighter exit on the drivers side the torino had the odd looking quick turn I didn't like. Weiand 8021 is the intake. I'm not sure yet if it clears the hood. I hope if it doesn't I can use the 80s mustang GT scoop that gives 2" more clearance. I have the rear disc change over but will probably wait until the rear brakes need changed. I used lokar throttle cable and lokar tv cable. I still have the 8.8 rear. I am thinking I will need to change it when it dies but I did put on the cover brace to keep the c clamps in place to give me a little more time till till the dreaded boom!!!
    Nov 1982
    Wetumpka, AL
    20,424
    Wow.
    Wow.
    WOW!
    Glad you are here
    Member Andypot1985's Avatar
    Sep 2010
    Scranton PA
    291
    oh my wow. excuse me while i pick up my jaw
    2002 Nissan Maxima 6spd 14.2@98mph "it may or may not be street legal"
    2009 Chevy HHR Panel - My office
    1988 Lincoln Town Car - The new love of my life
    Full-size Ford/Lincoln addict RyPow's Avatar
    Jun 2011
    Guelph, Ontario, Canada
    434
    SWEET. I like where this is going. It will kick arse and surprise more than a few people. It would be great if the intake cleared under the stock hood...then she would be a REAL sleeper! I want to put a built AOD behind the 429 in my '68 Galaxie and would love to know more about how you set yours up. I started the old Ford game with a '76 Thunderbird with 460/C6 and I originally planned to do porting, 40 over, 9.5:1 etc but that never materialized. I wanted to do a 521 stroker in my '79 Town Car, but the issues with the glass roof scared me out of keeping that car. I had the big-block blinders on until I picked up my '81 F-150 with the 302 and I'm warming up to the small-blocks. I'm not made of money and want to actually be able to afford to drive my toys. Those big blocks drink!
    RyPow
    1987 LTD Crown Victoria LX sedan - The "Sand Box" - 73K, towing package
    1987 LTD Crown Victoria LX Tutone Tudor - '96 Explorer 5.0 + 5spd swap in the works
    1985 Lincoln Town Car Cartier - previously owned by "navguy12" from thelincolnforum.net
    2007 Lincoln Town Car Signature Limited, 102k, daily driver
    1977 Lincoln Continental Town Car, 42k
    2012 F-150 5.0L 4x4, HD payload pkg (towing/hauling)
    2006 Mercury Grand Marquis LS, 115k, for sale
    2015 Toyota RAV4 XLE AWD (better half's)
    Jan 2007
    Westmont, New Jersey
    10,333
    I would recommend big brakes in the front. So you're gonna run an AOD behind this thing?
    Nov 2006
    Dirty Jersey Yo!
    7,862
    Sorry, I got no words for this awesomeness!
    The trash heap has spoken! Pesty351's Avatar
    Jul 2006
    Tyndall AFB, Fl
    2,577
    Super sweet.
    1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
    38,479
    Very cool. Do my eyes decieve me, or is that an AC compressor? If so, extra cool points for having air conditioning.
    panther lover forever gabegt90's Avatar
    Damascus Maryland
    5,407
    Very dam cool mang nice car
    Play me something funky! marquisman's Avatar
    innisfil, ontario, canada
    10,110
    that lincoln is so awsome on so many levels. i love the sleeper look too!
    1981 Mercury Marquis Brougham 2-Door 302 special blend (GMGT)- Summer fun
    1987 Lincoln Mark VII 302 (Errand runner) Summer fun
    1997 Lincoln Town Car Cartier 4.6L (Hustler) Summer Sunday cruiser
    2007 Lincoln Town Car Signature Limited 4.6L (Un-named) Daily
    I Am The Coupe Man. 81_TC's Avatar
    May 2010
    Canada
    55
    Quote Originally Posted by P72Ford View Post
    Nicely done.
    If it's a C6, a tv cable or rod is not required.
